- Thread starter
- #81
I thought I would give an update on the car. During the process of getting ready to pull the oil pan I found so bearing material in the oil coming out of the pan and in the filter. I decided based on that the engine should come out and gone through to see what is going on with it. So I pulled the engine last Sunday and took it over to JBA. So far we can see the thrust bearing is worn out again. The last time the motor was opened up to add the bigger cam and shaft mount rockers we noticed the thrust bearing was worn out. Here's a picture of the first thrust bearing after it was removed.
Here's the one that was just pulled from the motor.
When I originally built the motor I set the thrust clearance to what Woody at Fordstrokers recommended. After everything was torqued down the crank still had the proper clearance I had set it to. I thought the most likely reason for it getting burned out so fast was due to me having the clutch adjusted to tight and I was putting pressure of the thrust bearing causing it to wear out. After the bearings were replaced the last time I went from the T5Z with Maximum Motorsports clutch cable, quadrant and firewall adjuster to TKX with a MDL hydraulic clutch setup with a Tilton 6000 throwout bearing. I set the air gap for the bearing like Tilton recommends and after installing everything I could see I had a over an 1/8 of an inch between the throwout bearing and the clutch fingers so I know I had it set right.
Now I'm down to figuring out what I'm doing wrong that is causing the thrust bearing to wear out. In hindsight I should have checked to make sure after installing the clutch and transmission the engine still had the proper thrust movement. It could be the transmission is pushing the crank forward or there's an issue with the crank. The motor is getting completely torn down to clean it out and even though JBA has a bunch of engine builds in progess right now they are fitting me in to get me back on the road right away which I really appreciate. It's really nice to have the support of a great shop and amazing team of people.
