S197 Adjustable shocks
42
32
Nova Scotia Canada
both rear stock shocks on my 2014 S197 have failed and I’ve been looking into aftermarket/performance replacement
my main question is. Are adjustable shocks worth the extra money and is the adjustability actually noticeable
I am a student trying to build a fun street and track car without having to spend an arm and a leg.
any recommendations on specific parts is greatly appreciated
1,191
Lenoir City TN
I ran koni oranges with Steeda sport springs on my 2011 for several years and was happy with the combination on street and track. The car was more composed but not too harsh. I switched to Koni yellows and Steeda competition springs when the oranges started getting tired. The ride is a little stiffer but I like the handling better.
The oranges were kind of like the yellows at the softer end of the adjustment. Once you dial in the adjustment to your liking you probably won’t play with them much but it us nice to be able to dial them to your liking in the beginning. Non-adjustable are fine if they are a good match for the spring you are running.
42
32
Nova Scotia Canada
Awesome thanks!
Is there a way to know if the springs and shocks are a good match other then just using them on the car? I’m thinking something in the specs
1,181
1,191
Lenoir City TN
There is no spec that I am aware of. If you’re running stock springs you should be fine with koni oranges, Bilsteins or even the Steeda brand non adjustable shocks. The koni oranges and Steeda S-197 shocks are similar. Steeda engineers have told me they use which ever is in stock or on sale at the time. If after market springs ask advice from seller as to a good shock pairing.
42
32
Nova Scotia Canada
Okay awesome! I’ll do some more research
343
362
@Tim.ocon Yes the adjustability on the Koni yellows is very noticeable. Two common "much better than stock" shock options are the Koni yellows or Bilsteins. The Konis are rebound adjustable but the Bilsteins are monotube and a lot of people consider them a little better quality. But either is a great choice. I've used both and the flexibility of adjusting the Konis is nice.
Be sure to check out Billy Johnson and his build thread on the S197: https://motoiq.com/project-budget-400whp-s197-mustang-track-car-part-7-springs-shocks-and-bars/
42
32
Nova Scotia Canada
I was looking at that thread earlier and it seems to have a lot of good info.
I think the konis will be what I end up going with
We loved our Koni Yellows for the price on our S197 when we ran it in street class autocross. Turn then "stiff" for autocross and then "soft" for daily driving (My wife drove it daily for 3-4 years). You could definitely feel the difference between stiff and soft.
DaveW
