steveespo said:Just pulled the trigger on the Maximum Motorspots JRi 2 way adjustable set up.
Way to go, Steve!
Looking forward to hearing your impressions on this setup
Woo damn! Very interested in your feedback. Been talking to Brian at HVT recently as well and may be adding their custom 2-way dampers to my set of options...steveespo said:Just pulled the trigger on the Maximum Motorspots JRi 2 way adjustable set up. MM Deal of the day $4608 shipped. Thanks to 2012-Boss for the phone call heads up 8)
Went with 600 front and 375 rear spring rate, springs are cheap (relatively) so if fine tuning is needed or if I get big aero we can swap easy. Now the question becomes, do I get them in time to install prior to leaving for VIR on the 21st? Probably not but I am a sicko.
Steve
ArizonaBOSS said:Woo damn! Very interested in your feedback. Been talking to Brian at HVT recently as well and may be adding their custom 2-way dampers to my set of options...
twistedneck said:I decided on Cortex 2 way front 1 way rears. Cheaper than the Maximum motorsports stuff since its only one way in the rear Jri.
500/300 spring rate. Not sure how Fillip valved them but he asked what I wanted I told him I drive it one day per week in the spring / summer / fall and track it once per month during that time.
they look super nice - no fancy strut body like the Maximum kit, but they still use the nice Maximum upper camber plates.
Not used to the ridiculous shaft diameter on the front strut it looks almost like overkill.
http://checkja.com/images/cortex-coilovers.jp]
[/quote]
Nice
NFSBOSS said:Jeff, very nice. Did you buy the offset front struts?
Grant 302 said:Does everyone see the CorteX black friday deal ad here? 10% off...and it says JRi coilovers, watts links, and torque arms!
