Suspension rubbing/vibration noise
cobrarob
11 Shelby GT500
555
131
new york
Started hearing and feeling a little noise/vibration at speed at Watkins in turns
The only thing I changed from the last time I was there was the Front sway-bar setting
from middle to the stiffest setting...would that cause it?
Took the wheels off didn't notice any rubbing or anything loose.
302 Hi Pro
2,009
441
Southeast
The only thing I changed from the last time I was there was the Front sway-bar setting from middle to the stiffest setting...would that cause it?
How did you feel the vibration? Through the steering wheel, or the pedals? Or did you notice the vibration through the seats, or interior rear view mirror?
Trying to pin down the source from the front suspension, rear suspension or brake system.
You should check your front hubs for bearing play and noise as mentioned by 06Mach1. Also while you're there, inspect brake pads, rotors and tires as well.
Any more information on the noise? Is it a squeal or metallic grinding type noise?
Regards,
Dave
cobrarob
11 Shelby GT500
555
131
new york
It sounded and felt it in the seat more like a rubbing, initial thought was
tire rub on cooling ducts or end link bolt. When I shook the rear end their seemed to have a lot of play on drivers side rear end. Gonna bring tomoro to my buddy to
check t out more. Keep you posted,thanks for tips.
Mike I just changed the front wheel bearings last month didn't seem to make noise when I checked.
The noise was only heard and felt at full speed/lean on turns
Thanks Mike and Dave
302 Hi Pro
2,009
441
Southeast
Cobrarob said:
When I shook the rear end their seemed to have a lot of play on drivers side rear end. Gonna bring tomoro to my buddy to check t out more. Keep you posted,thanks for tips.
The noise was only heard and felt at full speed/lean on turns.
Good idea to have it checked out, as this is a concern. Usually when you feel/hear this in the seats, it is drivetrain or rear axle related.
High speed leans creates side to side movement in the rear axles, so pull the rear wheels and start there. Also inspect the rear caliper inner brake pads for wear, sometimes our ponies will wear inner pads first.
Good luck and let us know what you find.
Dave
2HP
steveespo
Lord knows I'm a Voodoo Child
4,025
1,979
Cookeville TN
Rear axle bearings, rear axle end play, worn control arm bushings, worn panhard rod bushings can all cause these symptoms. Rear wheel bearings are not likely unless the noise is constant and rises and falls with speed. Check into this because if axle end play is the cause it may be ready to lose a C clip and spit out an axle.
Steve
cobrarob
11 Shelby GT500
555
131
new york
Just talked to Dave my instructor, he said he felt it thru
the frame/suspension. Hopefully get outta work early
to do some searching! Thanks again guys, thanks Steve.
Let you know
Rob
cobrarob
11 Shelby GT500
555
131
new york
Checked/cleaned and greased all the bushings,checked over the suspension
couldnt find anything that made the noise,everything looked good.
Went out for a while hit some on and off ramps-no noise!
Have to wait for LRP
