TMO Is Now a Tire Rack Affiliate
Fabman
Dances with Racecars
6,556
8,208
Here is the direct link...I believe this will still go through TMO portal....yes?
<removed link>
Correct hyperlink-- http://www.jdoqocy.com/click-8231770-11960262-1469212524000 (ArizonaBOSS)
Fabman
6,556
8,208
Ordered tires for my daughters mustang....yes, we all have mustangs.
Fabman
6,556
8,208
ArizonaBOSS said:
Fabman now you have a donor car if you need to scrounge some last-minute parts >:D
There's nothing on there I can use...besides, she's pretty attached to that thing-I could never pry her fingers off of it.
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
Let's see some photos of that fresh rubber mounted up!! >:D
Track season is coming soon for most of us--get your track tires in-house and mounted up now! :)
Why doesn't tire rack carry Nitto?
This might of been discussed already but i can't find any details on it.
TMSBOSS said:
That would be nice. I also run Nittos. A business decision no doubt.
The best prices for Nittos I have found are at Discounttiredirect.com.
Anyone else have a different supplier?
I found decent prices over at tirebuyer.
TMSBOSS
7,559
5,294
Illinois
Two years is a little soon. After Seven years it's a must do maintenance item. Desert sunshine will of course accelerate dry rot.
Also be sure to use Trailer Tires. A car tire is Not made to take the twisting and heat a trailer tire is subjected to.
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
You may have noticed the Tire Rack ad towards the top of the page.
Please support TMO by purchasing your online tires, wheels and accessories with Tire Rack by first clicking on the ad and then when the new window opens place your order as you normally would.
This will not add any costs to your purchase and a small portion of your purchase will go to help support TMO.
You can purchase tires for your Mustang, street tires, track tires, wifes tires, tires for your tractor or for your Boeing 747. It's easy to do. Please let us know if you have any questions and thanks for your support.
If you cannot see the banner ad to click (as described below), please use this link: http://www.jdoqocy.com/click-8231770-11960262-1469212524000
Please note that with the forum software update, the location of the Tire Rack link has moved--it is now on the right side of the main page, as shown below:
Have fun and burn rubber!
