What did you do to your GT350 or S550 Mustang today?
496
390
DFW, TX
Now if it would magically install itself on the car...
Slot for tow hook cut, enlarged air inlet, and toned down the fake R badge with some metallic vinyl.
I guess I'll investigate closing off the radiator opening a bit before really putting it on the car. I have a couple ideas to mimic the R.26500dc643689de0feaf6a6c615ed5d1.jpg
Sent from my SAMSUNG-SM-G900A using Tapatalk
Good call picking up those used pieces.
Had a shop change my clutch. Stocker had a lot of meat on it, but the adhesive deteriorated and allowed the clutch material to pull apart from the ring.
I had the shop install an Exedy Hyper Single clutch, flywheel and another slave cylinder and braided clutch line.
The clutch now feels like a cable actuated one and quite a bit different than stock.
Gotta break it in and then hit the track again.16c2291b658360058e4c0c96a24d360e.jpg7fe85fb28e0c938b4f03d042a0117500.jpg0b34f8e405b14c0393a1326e05c5cb78.jpgc679077467cc996fd132b1f939062596.jpg881db7fa8c4bf9604987c77cd999c53a.jpg
Sent from my SM-G960U using Tapatalk
Got R-S4s mounted up last week for daily/track use and threw them on this weekend while I was swapping off the Drake end links. I reinstalled my old end links and just moved the MR shock wiring to not interfere. I can't deal with the annoying heim joint noises for a daily driver.
1,066
1,120
Monaca Pa
That’s a lot better than working in my driveway lol. I just finished putting a Velossa big mouth ram air, longacre splitter rods and Blowfish tow hook. Now I need to fab
496
390
DFW, TX
Since I'm installing a hood vent, I cut, heated and bent a piece of ABS sheet to mimic the R grill opening.
I always thought just the center was raised on the R, but even the ends are reduced from the normal GT350 grill.396deb829c01ef956a5bec26223474b7.jpg
