ArizonaGT said:The part people usually complain about is getting the hoses onto the spindle ducts; we did this in less than 5 mins for both hoses by spraying a little WD40 inside the mating part of the hose, then pressing the spindle duct into the hose using a screwing motion.
Getting hoses on can be a pain. IMO I wouldn't/didn't use any WD-40 since it makes it too easy for the hoses to slip off once they are on. I made cuts into the spindle ducts to reduce it's diameter slightly, there are pics on the 'net describing this. You will need to adjust the mounting of the horns on the drivers side, they will be in the way. Also some people have had issues with the windshield washer tank on the passenger side. I also foind tha the hoses do not like to stay on the grile intake ports either, I used some additional tie-wraps to help insure they did not back out since just tightening the clamps just forces the hose to pop off on it's own.
