- Thread starter
- #41
- 602
- 539
Thank you Jdee for your words, It's helps.
The "Tinkermoble" is in California. So Button Willow, Laguna Seca, Sears Point, Thunder Hill, Willow Springs. I have yet to do Auto Club and really want to.What part of the Country are you in, and where have you been tracking the Tinkermobile lately?
Why thank you, that's so nice of you to say.@Tri-bar has been to a TMO track day at LS. He's a true gear head.
I've always wanted to do the Silver State 100
https://sscc.us/
I will as soon as I put them back on.Pictures are worth a thousand words... post up the new wheels on the car!
@Tri-bar can you give us a long-term review of the H&R coilovers? I know you switched to JRZ, but do you feel the H&R kit was a good entry point?So here my take on the H&R RSS Club sports Struts and shocks. Keep in mind that I have run and tested damn near every thing out there. KW/Roush, Koni, Bilstein, Tockico D-Specs, Ford Racing Shachs coil overs for the Boss 302S, KW v3's and last the JRI's singles. I bought the H&R kit with the 630/515 spring set new for around $1400+. Once the box came, I unboxed it all. It's very well packaged with no chance of damage. The build on the struts and shocks are top notch. The main strut body is a custom built one from H&R. Polished stainless steel housing, not paint. With the inverted strut sourced from Bilstein. H&R reworks it to fit their adjustable piston rod. It is one solid unit. Side by side the H&R unit is shorter than the JRI unit.View attachment 7955
As you can see side by side. The H&R is much shorter. Once it's on the car when you raise it off the ground, there is very little drop. The adjuster is on the bottom. Not the easiest to work with but one turn of the wheel gives you access to the adjuster. I had to set my adjustment range to match because it didn't seem set from the factory as even. Playing with them for 40 min got them evened out to match. Once set, I adjusted them from soft 6 clicks or 50% dampening.
The rear shocks are in custom, polished stainless steel housings. Compression valving is set super stiff. I got blisters on my palms from trying to compress them. The are under pressure so the rebound comes back swiftly. Setting them side by side with other shocks really showed how short they are. They are even shorter than the Roush/KW shocks mounting point to mounting point, that was a shocker! The rear shock are not adjustable.
When I first installed them, I only installed the fronts and used the JRI's in the rear. Set ride height, from ground to fender lip 27 inches. That placed the spring really high up there.View attachment 7956
Spring rate is 630lbs. You might think that is stiff. You would be wrong. As it turns out, it was dead perfect. With my front Strano sway bar on full stiff and the 50% dampening it turns out right on the money. The spring has a working range on maybe 3 inches. The rest are dead coils that act as a helper spring. Using the JRI rear coil overs with 225lbs springs, The beast was very well behaved. After that I installed the H&R rear set up, The Shocks and the 515lbs rear springs. It wasn't too bad. Just a tad of overseer on power, exit of the corners. Pulled it all out, put the JRI's back in and ran that for a few days. It was damned smooth, ate up bumps like they didn't even exist. Life was good.
UNTIL I went to put on my newly gotten Apex 18x11 wheels with 305-35-18 NT-01 tires. That's when the set up ran afoul. The Wheel hit the coil over adjuster at drop. So what to do. I ordered Maximum Motorsports rear adjustable spring seats. Moved the springs inboard, up the rate to 300lbs. Added 10 clicks the JRI's. Now also at 50% dampening. 30 clicks out of 60 and was all good. The beast rode smooth over the bumps. Had good grip into and out of the corners. For a what the hell moment, I put on the rear H&R shocks on. Well, they are staying on. The ride is a tad firmer but well controlled over the rough stuff. bumps do not upset the rear at all, it just eats them up. When the street tires on the car, grip into and out of the corners is well like a race car, fast in fast out. Then I test drove the new wheel and tire combo. It is GOD like, grip for days and might give you change back at the end of the day. I can power on so much earlier at the apex it's scary.
H&R claims their strut and shocks have dynamic dampening. They really seem to. With the fronts set to 50% dampening and the rears set to whatever the factory sets them at, they just works. Freeway speeds you feel the uneven stuff as any car would. but if you hit a bump, it goes over it with no fan fair. I now hit bumps the would upset the car with other strut/shock setups, even the JRI's and acts like they aren't even there. It was very nice to see that. The claim is big but I have to say, for my car. H&R has the best setup I have ever tried. There are cons however. Don't use the rear springs. They are just to dang stiff. It's not that it's a bad ride. Better than a lot of setups. They add over-steer to the car. I run a small rear bar, 1/2 inch small and the 515lbs springs are to much. Drop down to a lighter spring, I picked 300lbs and it worked out great. The other con is the adjuster on the front strut is on the bottom. You hjave to turn the wheel to gain access, then you get dirty on the ground adjusting them. Not a fan. The good is set it up once and forget it, I don't think you will ever need to change it.
There is my $0.02 worth. It is a surprise that something at that value point can be so damned good. I might have to buy another set just to keep as a back up.
The H&R RSS Club sport are a very good entry point coil over. The rears springs are to stiff and can be swapped out with a lighter coil over type spring depending on sway bar choices. SMGDHG has them on his car now. He runs great times with a 08 4.6.@Tri-bar can you give us a long-term review of the H&R coilovers? I know you switched to JRZ, but do you feel the H&R kit was a good entry point?
