- 6,429
- 8,335
I wonder if that was an engine built to run on ethanol? I know there is a ton of power to be made by running alky, but to take full advantage of it, you need to build the engine around the fuel. (sprint car guys as an example). There's a lot of advantages, like less temp, no pre ignition, and you can really put the boost (or static compression) to it. I'm just not sure that you can gain a lot by simply changing the tune.The flame front speeds were an answer to a question I asked the Pro Commander folks. I asked why they didn't adjust timing (only fuel injector pulse width), and the answer I got was flame front speeds. It made sense so I pondered on it for a while.
The following is from google, so until I get a little more solid reference, I'll just put this out there.
Flame tomography showed that at radii between 8–12 mm, ethanol was burning the fastest, followed by butanol, iso-octane and gasoline. The associated turbulent burning velocities were 4.6–6.5 times greater than the laminar burning velocities and about 13–20% lower than those obtained by flame chemiluminescence imaging.
I'm far from an expert, all the alky engines I've been around have been in sprint cars, so I don't have all the answers, but when I saw the flame front statement, I had to question it, as an example, if you dump a quart of gas and a quart of alky on the ground and light it, the gas will burn much faster, so it seems odd.
