- 401
- 0
Any particular reason you chose the the twin 65mm TB? How about the super cobra jet single oval? Honestly asking because I dont know much about how much flow is ideal for the CJ intake.
steveespo said:Twin 65mm is alot of airflow for a NA application, Single Oval is even more and is good for SuperCharged applications. The twin 65 will be better for idle quality and throttle resonse which are important for Road Race performance. I may even get the stock GT500 twin 60mm TB if the dyno shows any low end issues with the big bores. It is very cheap brand new, like $125.
Steve
steveespo said:Did some calculating and the twin 65mm TB is approxiametly equal in area to a 92mm round TB= 6650 square mm, Twin 60 is about a 85mm round= 5652 sq mm. Stock 80mm round is 5024 sq mm in area.
Steve
That is correct, so is Bill, thats why I chose the twin 65.Justin said:I read an article on the twin vs oval and the oval on an na car usually hurt performance over the twin due to port velocity where on a positive displacement supercharger this isn't a factor as it's pulling in the air. Kenne bell did the testing I believe.
sadil said:Steve,
What is required to install an Intake and Throttle Body? I know the tuner adjusts for a CAI by stepping up the flow expected by the ECU, is it a similar process for a high capacity TB and Intake?
