Front A arm bushing cracked, change bushing or A arm??
5,261
4,259
On checking out the car, found that the right rear Front A arm bushing had a split going almost all the way around. Is it worth upgrading by going to a BMR A arm (adjustable or not?) or just get a upgraded bushing kit??
599
537
I'm running the Prothane kit on mine. zero issues. old bushings are a pain to get off though. Not a fan of the BMR arms or any of the tubed arms for that matter. Upgrade the stock arms.
302 Hi Pro
2,009
441
Southeast
In October 2014, I had my dealer replace both front lower control arm bushings under a TSB, (Warranty). New parts came with new control arms, bushings and ball joints.
Did you have any front end noise over bumps on sharp turns, like k turns, etc.?
Just an FYI,
Dave
5,261
4,259
I do have a little slop in the steering but that was the only warning. No tsb for me. I imported the car direct to Chile to get a manual box.
Mad Hatter said:
I was suprised to see only BMR arms availble. They do seem rather skinny. Will get the bushing kit.
BMR redesigned their arms and stand behind them however those and the Kenny's browns are no where near the strength of OEM control arms.
The rear bushing and mount kits for the Boss 302S are almost $500. If you decide to replace your own its supposed to be super difficult. I think Cortex was working on a less expensive replacement bushing than the Boss 302s one.
5,261
4,259
Considering the state of most of our tracks down here, I think I will go with the Prothane A arm bushing. Some of the pianos are bad enough to knock the wheel of a GTR!!
599
537
I used these on the rear
http://www.latemodelrestoration.com/item/PT-6220BL/Mustang-Prothane-Black-Front-Control-Arm-Bushings-Replaces-Rear-Mounted-Hydra-Bushing
Front
http://www.latemodelrestoration.com/item/PT-6218BL/Mustang-Prothane-Black-Front-Control-Arm-Bushings-Replaces-Front-Mounted-Bushing
Front
How about the install on the rear bushing was it difficult?
5,261
4,259
Am confused. Just got an email from LRS saying those bushings will not fit on 2011plus??!! But they look just like the ones MMsports has...
Not 100% sure, but I suspect different hardware/bolt sizes. IIRC, a lot of the hardware was updated in 2011 and not interchangeable with '05 to '10 cars.
5,261
4,259
Hmm. Looks like a cheaper way is to just replace the whole right side A arm for 125 bucks. The ford racing bushing kit is 499!!. Makes the bmr kit look better.
steveespo
Lord knows I'm a Voodoo Child
4,025
1,976
Cookeville TN
GTs '11 and '12 have the rack nibble vibration issue with urethane or spherical bearings up front, mine did and changing to the FRPP rack cured it. I've heard of Boss cars having it but not many, if you have you know it, it's like someone is moving the steering shaft back and forth an inch twice per second. It's not a vibration.
Steve
twistedneck said:
Did the issues with your rack start AFTER you changed control arm bushings? That seemed to be the case on the Vorshlag car..
That's what happened, IIRC. He changed his steering rack to a '12 unit and the vibration went away.
My GT had shown the shimmy a couple of times when it was new and in the cold, and never seen it since, but it has made me wait on installing bushings up front until I have another rack in hand.
Steve
Thanks for clearing that up steveespo. I have a 2012 GT and i was about to upgrade front control arms and bushings to Boss 302s w/ urethane.. at this point i'm going to hold off on that until i can afford the FRPP rack. Glad i followed this thread.
Though rare, I encountered the dredded steering shudder after installing the KB AGS-4 on my '13 LS. The only cure was the the FRPP EPAS rack. The link below is the thread.
https://trackmustangsonline.com/index.php?topic=7421.msg118827#msg118827
r
Eric
I don't think it's an issue on all the '12s, if any. I only heard of the issue on '11s.
Since you have a '12, I would just try the arms or bushings and see. Might save you $1k for the rack.
