GT 350 brake calipers
I asked about that yesterday and they didn't have an answer. Fortunately they use a radial mount which makes removing the caliper about a two minute event vs 20 on our cars.
680
215
That bridge really stiffens the caliper. It's on most of the six piston BBK kits sold by Brembo. The 15" Aftermarket kit sold by Brembo for our cars have this feature but not the OEM GT500 (2013-14) calipers. I thinks it's a great addition to the new car even though pad changes will be different.
ArizonaBOSS
Because racecar.
8,731
2,734
Arizona, USA
This. Two easily-accessible jet-nuts and the caliper is off in a flash. Should be much faster.
ChopSui said:
Pretty sure the spindles are aluminum on the gt350
He was referring to the procedure on the S197 cars. Many of us have stripped or had to clean up the threads on our stock Brembo calipers. My Stoptech spec Mustang kit uses a radial mount like what is on the new GT350. Soooo much better. I wish the rears on the 350 used a radial mount as well.
180
40
Austin
That doesn't look like a nut on the end of that caliper. Looks more like some kind of hex socket bolt. Am I seeing that right?
Here's another view:
Here's the bare knuckle:
If it's what I'm thinking, I might need to get a bigger tube of anti-seize.
ArizonaBOSS
Because racecar.
8,731
2,734
Arizona, USA
Looks like it to me. Hex bolt just as simple. If you don't have a good set of (metric) allen hex sockets for your ratchet, this is a perfect excuse to get one. :)
I was wondering the same thing after posting that photo. No posts like my Stoptech setup which is a shame. I wonder if it can be converted? Not screwing a steel bolt into aluminum (again) would be my preference.
1,938
2,041
Certainly looked like Steel on Aluminum, so more Anti-seize! Even with improved brakes, pads are going to be changed often...
I've been using Anti-seize with 10% lower torque on the Boss for over a year -- no issues loosing torque, and no more striped threads from the loctite! I would't advocate for a daily driver that does't get torque checked frequently.....
The recommended torque seemed excessive on the stock calipers but I understand that on a street car where the calipers get removed once every 50k miles it's not an issue. I was also using lower torque and no additional loctite on mine. Please use loctite if you're not checking yours regularly.
FWIW the race brembos use a similar setup to my Stoptech's. I wonder if CorteX can make a stud and jet nut conversion kit? Hmmm another product idea... ;D
@CorteX Racing
