Heading to the strip tomorrow
unrealford
Mustang owner since 84
521
0
Re: Re: Heading to the strip tomorrow
roadhouse said:
Unreal- Thanks and you're right, it's not easy! I almost purchased the MTs. You have some very impressive times for a stock with tires! Congrats. What is your launch technique to get your 60ft into the 1.6 range?
I launch around 5,000k and slip the clutch lightly. I also run 23lbs air, the lower the air the worse my 60ft got.
1,281
3
Tulsa, OK
Ok. Yeah I'm launching pretty much the same but not slipping the clutch like I should. More just dumping it. Interesting about your tires pressure. I still need to play around with the Hoosiers a little. Thanks for the info!
