The 71 is too tall for the car and will rub the inner fenders unless ride height is 4x4 like. With 68 Michelins and a 3.55 gear I hit 171 at Daytona start finish at 7200 RPM 1:1 5th gear. With the 65s car hits 152 at VIR 5th gear at 6900 RPM. With the 1.13 5th and 1:1 6th in your sequential you could just run 68/680s at either with 3.55, or go 3.31 and run the 65/650s where you need a little more gear. I am jealous, wish we could have an H pattern box with those ratios.I was thinking I'd be running the 705/710s in the rear which come in around the 27.8 height. Do you recommend the 65/68 heights instead?
