Introducing "Project 6GR" Spun Forged wheels For S550 Mustang & GT350
Which Color Wheel Would You Prefer
  • Gloss Black
    Votes: 30 39.0%
  • Matte Black
    Votes: 26 33.8%
  • Flat Graphite
    Votes: 21 27.3%
  • Total voters
    77
180
40
Austin
VoodooBOSS said:
Did you order the ones that Moto and I were discussing? If so order the 13/16" Gorilla socket with the red plastic sleeve. Remove the sleeve and you'll be in business.
This guy
https://www.amazon.com/Gorilla-Automotive-1316TWS-Impact-Protective/dp/B002803ULQ/ref=sr_1_3?ie=UTF8&qid=1468020784&sr=8-3&keywords=gorilla+13%2F16%22+socket
Well I got the socket today, but unfortunately, it does not fit the lug holes even with the sleeve removed. It is the 13/16 and it fits the lug nuts, it's just about .5mm or so too big for the holes. I tried front and rear wheels just to be sure. :(
Hmmm. I just checked mine again and it fits with room to spare. Mine is marked "13/16" Gorilla CR-V" and it fits over the Ford Racing 13/16" open lug nuts. Looks just like the one from Amazon and that's where I purchased it from. After looking at the image closely it's different from the one I have. Sorry about that. I've had it for about four years so maybe they changed it. @cloud9 recommended it to me for our Enkei wheels.
@Need4SpeedMotors are the lug holes the same on the R spec wheels as the other wheels? I have the 19x11 rear wheels for both front and back.
The one in this ebay ad looks like the one I have. Check the depth of the area where the engraving is. Maybe ask them if the socket has CR-V on it and if so give it a try.
http://www.ebay.com/itm/New-Gorilla-Thin-Wall-Impact-Socket-with-Protective-Sleeve-13-16-SAE-/391458952481?hash=item5b24c59521:g:x0gAAOSwyQtVhHmz&item=391458952481&vxp=mtr
180
40
Austin
I measured the outside diameter without the sleeve and it's 28.8mm I think yours had measured 27.something. I bet they added some thickness for strength. I know some of the reviews complained of cracking when using a lot of torque. American Muscle sells a socket that they say has an outside diameter of less then 28mm, so I might try that. The holes on the wheels are 28.25mm so I know it will fit. Just not sure about the quality.
http://www.americanmuscle.com/thinwall-socket-13-16.html
@VoodooBOSS Yes sir they are all the same.
The 19 mm socket we use and lug nuts have worked with plenty of space to spare.
VoodooBOSS said:
The idea of the larger lug nuts is to provide more contact area between the lug nut and wheel for track use. The smaller lug nuts are fine for the street and probably the track too but I’d rather use the larger ones for the track.
Have you tried these new bigger lug nuts with the Project6GR wheels yet?
141
4
AMPowerJ said:
Here are mine!
I saw AMPowerJ's on the main site banner and had to say something. That focking thing looks AMAZING. WOOF. Great job on the gunmetal with the red. I would have never thought it would look that good (the great detail and lighting certainly help too). NICE CAR!
Agreed. Looks absolutely fantastic 8)
Thanks guys and I'm honored to have my car as the banner. I did not expect that. This wheel is a solid 10 when you factor looks, cost, weight, etc. If you don't have a set, you don't know what you are missing.
Hey guys,
I switched to 13/16 lugs and used both a standard Craftsmen 13/16 socket as well as a Craftsmen 21mm and both fit the R-Spec wheels perfectly.
I ordered and used these lugs:
Front wheels: McGard 64023 Chrome (M14 x 1.5 Thread Size) 1.95" long
Rear wheels: Gorilla 61147 Acorn Bulge (M14 x 1.5 Thread Size) 1.4" long
Chris M
180
40
Austin
Well I finally got those Dorman ebay lug nuts installed. I definitely need to get some studs. As you can see, the rear OEM studs aren't long enough to use all of the threads on the nut.
are you getting atleast 6 turns on the rear with them?
180
40
Austin
50Deep said:
How many threads do you have on the rear? Is because of the lug nuts or do the wheels have too thick of a pad?
I'm getting a little over 11 1/2 full turns on the nut before it's fully torqued. I haven't tried mounting one of the OEM wheels to see the difference. Just for reference, here's a pic of the N4S supplied tuner nut, the open ended nut, and the OEM nut.
