This photo doesn't really show anything with regard to spring rates. I'd be curious what spring rates Andrew runs on his car. I'll ask him.
With stock rear suspension geometry, 650 rear springs would be very high.But you can bet your bottom dollar its no where near 650 for the rear... more like 300 to 350. I would think that at 650 your going to have zero squat and not much traction.
Yes, the Mustang performance world lost a very special man! In spite of that Team KB continues to move forward with some very special projects on the board. Cheers!
WesD,What's your front suspension setup (besides the 650 lb/in springs and LS sway bar)?
Yeah. In reading the fine print, it's *up to, and I think they're talking about going from OEM to full K-B suspension. Regardless, that's kinda weird marketing.The latest KB ad claims "lower lap times by up to 11 seconds".
That's a pretty hefty claim right there....
Agreed. Personally, I'm more interested in learning what actual customers think of it, and so far, the feedback seems to be overwhelmingly positive. I know many of us are happy with our current setups, but I think "don't knock it till you try it" certainly applies.Not to be pessamistic, but most of us are pretty dam happy if we can get the car to be 1 second faster. Some major changes mean 2 seconds. But 11, that sounds like it was with two different drivers.
Agreed on all counts...at least in theory. What's weird: accounts of how this setup works on real cars leads me to believe there's more going on than we may realize. I'm growing more convinced that the extremely low roll center benefits a live axle car more than an IRS because live axles seem to be more sensitive to the jacking effect with above-ground roll centers. Maybe the corner exit bite from minimizing jacking the inside rear wheel outweighs the loss forward bite from stiff(er) rear springs. Going back to theory, however, if both rear wheels are more evenly loaded (from the low roll center), then the rear diff can be "looser," which also reduces understeer.I've been a big proponent of low roll centers since the 70's, It makes tons of side bite. ( My stock car had a 6" rear roll center)
The down side is it also creates body roll and under steer....sooooo if you can manage the those characteristics you can indeed be fast, but you have to deal with that.
The part I have a problem with is the 650# rear springs. If you have to throw away traction to balance the car, have you really done anything?
Maybe the roll center didn't need to be THAT low....plus super stiff rear springs will sacrifice forward bite so if you're making any real power that's going to be an issue.
I am interested to see how this works out.
I look at it like;Agreed on all counts...at least in theory. What's weird: accounts of how this setup works on real cars leads me to believe there's more going on than we may realize. I'm growing more convinced that the extremely low roll center benefits a live axle car more than an IRS because live axles seem to be more sensitive to the jacking effect with above-ground roll centers. Maybe the corner exit bite from minimizing jacking the inside rear wheel outweighs the loss forward bite from stiff(er) rear springs. Going back to theory, however, if both rear wheels are more evenly loaded (from the low roll center), then the rear diff can be "looser," which also reduces understeer.
All food for thought!
