Question on FoMoCo Adjustable Track Bar
66
49
Pittsburgh PA
Any recommendations on which side (axle or frame) to mount the adjustment nuts and which way to orient the bar ends since they are not symmetrical as compared to the stock track bar.
Thanks!
66
49
Pittsburgh PA
I just noticed the adjustable track bar is the same length as the stock bar fully adjusted “in”. Due to the geometry, I would have thought I’d be able to make the adjustable track bar shorter than the stock bar when lowering the rear to keep the axle centered.
It’ll be a while before I have weight on the rear and doing adjustments.
Any thoughts / comments?
7,557
5,293
That’s special. I bought the same part and did not have the same results. My PHB was shorter. You may want to call ford performance and see what they can do for you. See if they have measurements you can use to compare.
Beermomey has my old bar.
