R - Track Alignment
124
21
What are you guys running if different from FP issued specs.
My car: Dual purpose car running DOT tires. Will be running Apex wheels 19x11s with 305s squared when the wheels come out. Aside from camber plates, everything else stock.
I don't have an R but the recommended specs from Ford seem to be working well. If you're not doing a lot of track day and or not running the PSC2's then you can probably run less camber both front and rear.
Thanks!
I am reading all the online user manuals and supplements I can find in preparation for the delivery of my new GT350. I didn't see this info anywhere. Is it a separate sheet that came with car's owner manual, or is it online somewhere?
124
21
FYI... I asked the question here to see if anyone is running anything other than FP specs. I ended up with FP specs. I have only run 1 track day but seems to be working fine. GL!
124
21
Thats odd. I referenced my hard copy of the GT350 supplement on pg 44-45. Perhaps link I share is an older version of the supplement before FP issued the Track alignment recommendation.
You can either take the screen I shared to your alignment shop. I had a Ford dealer do my alignment as they had very high-end equipment and a technician who's done camber plates before. Ford has access to the specs.
1,250
1,244
In the V6L
They're not in the supplement. The track settings are on a separate sheet that's tucked into the package with your owner's manual.
1,250
1,244
In the V6L
I just got my free oil filter and wrench from Ford. In the box there was a new GT350 Owners Supplement, and sure enough, the track alignment settings are in the supplement, just as VoodooBoss says. So I pulled out the owner's document package that came with the car when I picked it up, and sure enough, there's the separate sheet with the track settings that I was talking about. So then I looked in the Owner's Supplement that came with the new car, and sure enough it's in that one too. So, now I have the track alignment settings in four places - three Owner's Supplements (this is Canada so of course there's a French one) and the separate sheet that came with the car.
They're everywhere...
8,507
8,549
Seems somewhat tame, is anyone running more aggressive with Hoosiers , for example?? Will have Hoosiers all the way around and installing M&M Camber Plates , so will be able to go beyond their set ups.
