I'm trying to find replacement front sway bar bushings for a 13 boss 302. It has the 34.6mm bar. All I can find is the 35mm bushings. Anyone know where to find the correct size bushings? Ford discontinued them. All of the aftermarket selection is 35mm.
Thanks.
Edit: Check the old bushings on pre 2010 cars.. looking now there was a 34mm bar back then, meaning that 34mm bushing should fit just fine and its not bonded so rate will be 7% less than the 2010+ bonded ones. But you will also need to get the matching brackets.. the cross section shown is the 2010-2014.. the first gen were slippy and had a different hump.
I'm pretty sure those were bonded on to the bar and they are not for sale without the front bar. The front assembly is made by Mubea, an excellent German company with plants here in the USA. Its not a great design with the open ears on the bracket so the rubber can squirt out and it has hysteresis when the outside of the bonded bushing slides against the inside of the bracket.. we fixed all those issues on S550. Back in 2003 when the S197 was getting designed nobody could do full rubber assemblies with preload and all that to see what was going on. I think in 2010 they started bonding them to stop noise. I remember doing research on this back in 2003 and i was able to pull data from like the 77 Tbird and some other crazy old cars that had noisy bushings, there was no fix at all for 50years! until 2013 when we designed the 2015 S550 setup.. thanks Ansys!
