if that is what the engineers wanted, they would have spec’d it.
As @honeybadger said, there's lots of life left in those - they look great! The Cup2's have minimal tread to start with, so they don't look worn until the little grooves on the outer edge are gone completely. Until then, you're fine. If it rains, slow down.These cup 2 have 4k miles and one track day. What is the opinion of this group for one more track day with a 200 miles round trip on highway.
I really appreciate all the feedback, and while tire longevity is always a tough question, I was just looking for some different opinions. My friend who is a former racer just said it simply, it’s a safety issue therefore there is no question, just replace them.Actually, having been in the Automotive Business for a total of over 30 years I can unequivocally state that what Engineers want is often not done or allowed. I could spend a ridiculous amount of time discussing a myriad of situations, but I will use just one example many on this Forum are aware of. When the Boss 302 was built the Engineers wanted and lobbied for the Tremec T6060, but the bean counters gave them the lovely MT-82. Like TMS I have been lucky to know many Ford and Dodge/SRT Engineers and we both know a couple of ( Engineer ) TrackRats on this Forum who run a square set-up on their track GT 350s, using lightweight forged or flow formed wheels. The average driver who buys a performance car never takes it to the track and in fact Corporate estimates often use 10-15% to represent the number of drivers who will autocross or track their machine. We are all just making suggestions to give you a safer situation, and we are not being argumentative, but trying to give examples of situations that can occur and hoping to help you and others avoid problems many of us have encountered. I can tell you when working at one of the largest Ford Stores in the Nation, CF wheels were on constant backorder even before the Pandemic. It is worse now, so a damaged wheel could not only hit your wallet , it could sideline you for a period of time. The irony is you could buy a set of wheels and tires for less than one CF wheel would cost , so it becomes an alternative also to make sure you get to the track as much as you are able. Hopefully some of our comments are helpful.
One comment I am always afraid to mention is how long a tire will last. Honeybadger says he could go on your tires for a whole day, and I do not doubt him one bit, but he knows the track he will be running the tire on. I know of one track in particular that you would have found it difficult to even make it one day. I have been very fortunate in my 41 years of autocrossing and tracking to go to over 20 tracks and I am always amazed at how different they can be on tires and consumables. That is the main reason I go to almost any track with two sets of tires and also why I am hesitant to say you can or cannot make another event on that tire. What track are you running on, some experienced drivers on TMO may be able to give you a better assessment if they run on said road course, often.
Car was setup by Trent at Sonoma with front and rear camber brackets, rear subframe connection and front brace and alignment so it should be pretty set.That tire has 2 days on it easy assuming your alignment is good. Could be less if you don't have enough camber.
I've run through about 10 sets of Cup2s on track and I'd go a whole weekend on that no problem.
