What did you do to your Boss 302 or S197 today?
ArizonaBOSS
Because racecar.
8,742
2,760
Arizona, USA
Re: What did you do to your boss today?
racered302 said:
Maybe you should have picked another color when you replaced you Boss, you don't seem to have very good luck with red ones.
Ouch!
Time to catch up. Last fall I installed T-springs. A couple of weeks ago I installed BMR lower control arm relocation brackets and J & M lower control arms. So I got back under the car today and installed the CHE upper control arm mount and Steeda adjustable upper control arm. Then I put up a CHE K-member brace with transmission torque links. And the Whiteline transmission brushing just for good measure. so it was quite a day and it feels like a completely different car, i'm very satisfied.
Howe industries ball joints are in. V-bands and Magnaflow 14419 bullet style mufflers are being installed. We'll see if this helps pass 90 dB sound at LS.
How easy is to change the ball joints? Any modification needed to fit the Howe?
I just installed the Steeda Boss arm and with the recent problem with X11 I might have to upgrade to Howe pretty soon.
Woke her up from a long hibernation and went for a 20 mile cruise. My face hurts from grinning!
1,281
3
Tulsa, OK
Installed new rear brake pads and rotors. Pads still have some good amount of life left on them but they were wearing very unevenly. And the rotors were less than smooth. I ran most of last year on these pads and I was surprised at how much pad was still left. Hoping the new ones will wear a little more evenly.
steveespo
Lord knows I'm a Voodoo Child
4,107
2,213
Cookeville TN
Popped out the Steeda X11 ball joints and popped in 2 more. One was bad, very loose with about 1/16" vertical play, the other seemed tight but I did both to be safe. The new set seemed to have a different main body than the ones I pulled out so maybe they had a revised supplier.
Steve
Beyond pressing the old ball joint out, installing the the Howe unit requires welding the sleeve onto the control arm. Thread the ball joint in after that and you're done.
steveespo
4,107
2,213
Cookeville TN
Yeah, I had to get the car ready and didn't want to pull the arms off to weld the sleeves. I have a spare set that I am going to convert to full 302 R spec including the Howe ball joints. I had hoped that the sleeve was a press in but I see you needed it fully welded around the perimeter.
Steve
I tried to remove my cats and put the O/R legs on but I could not seperate the legs from the collectors, it was like they were a solid piece. I tugged, twisted and did everything I could think of but no luck. I haven't driven my car 200 miles since the header install. I would really like a little input on this one be it seems like a simple enough job. What do I do now short of paying to get it replace.
dgc76
Life is good
MGW and modified Whiteline bushing insert. Wow! Now I can shift this beast. 2nd to 3rd at full throttle every time. Before I would miss it about half the time. Almost no increased noise, just a little in 4th. Thanks to you guys for posting so many good reviews and convincing me to go MGW.
