What did you do to your Boss 302 or S197 today?
1,281
3
Tulsa, OK
Re: What did you do to your boss today?
Replaced and re-routed the hose to the my diff catch can. There was a huge cut in it, which would explain why the back of my car was black at the end of the day ::)
1,940
2,048
Swiss Boss said:
Cool, Thank you. Looking forward for your track review.
My stock bushing should be near the end of his life after 2 years at the track but it was still good when I visually check it last week also don't have really much time to mess with it now. I'll probably change it this summer.
Based on this weekend only, I'd say there's noticeable improvement. Much of the clanking has reduced (probably play in the OEM busing). The car feels more planted at the rear on both power application, and braking. Lap times were improved at NCM. Finally, the car is now pushing more with understeer at the limit in corners. I think this is more likely exposing inherent set up, that is now more evident because I can push the braking and corner exit harder......
Would be interested in others comments....
The Rip said:
Installed Jacking Plates and Blowfish Racing Front Tow Hook.
Mods so far I have done:
Ford Racing BOSS 302 Specific Lowering Springs, w/Bump Stops (35mm RR, 15mm Frt.)
Ford Racing Laguna Seca Brake Duct Cooling Kit
Ford Racing Laguna Seca Front Splitter
Ford Racing Laguna Transmission Cooling Scoop
Ford Racing BOSS 302S Front Grill
Ford Racing BOSS 302S ARP 3” Wheel Studs & Lugs
Ford Racing Finned Differential Cover w/fill, drain & vent
Ford Racing Track-Key Programming (Red Key)
Blowfish Racing Fire Extinguisher Mount
BMR Upper Control Arm and Mounting Bracket
BMR Lower Control Arms
BMR Lower Control Arm Relocation Brackets
KOOKS Side Pipes
Mike Black Jacking Plates
STEEDA Front G-Track Brace
STEEDA Adjustable Panhard Bar
STEEDA Panhard Bar Brace
Cool Tech LLC Roll Bar & Rear Shock Tower Brace and optional Diagonal Bar
Cool Tech LLC 6-Point Harnesses
JLT Oil Separators
Allstar Performance Rear Differential Catch Can & Breather
Silver Horse Racing Black Billet Door Handles, Lock Cups, Mirror Knob.
Nice. May I suggest some Koni's.
1,940
2,048
Solved the mystery of my Starter issue. Car would not start when hot, and voltage at relay would slowly climb from zero to 14 volts as the car cooled down. Cold start was not an issue until recently.
Turned out to be a bad solder joint on the S- terminal of the solenoid:
steveespo
Lord knows I'm a Voodoo Child
4,031
1,998
Cookeville TN
Cool, strangest problem I ever saw. Glad you didn't have to change harnesses.
Steve
899
548
What? No more push starts to get you to grid? Glad you finally found the cause.
buland
One of the rare Boss LS in Switzerland
prepped the ls for season 2015.
but because heavy rain and storm i couldn't do the testdrive. i hope the weather is better on the easterdays.
installed the MGW Race Spec V2
installed the Airaid PJ CF CAI
and changed the Oil and Filter
cobrarob
11 Shelby GT500
555
131
new york
Changed all fluids...motor,tranny,rear and brake
Put on Sve's w/Nitto 555II 285/35 square for LRP on Mon.(1st time with r compounds),
let's see how it goes!
158
3
Finally installed the blowfish racing bracket. I bought the bracket last year and never installed it because as a newbie, i was not too confident doing it. It did take me a bit of time, but i watched the install videos including the 15 minute install one shot on xmas day...and then decided to give iit a try. Success! My only difficulty was trying to torque the upper and lower pieces that snug the shifter snout....I could not fit a small 10mm socket on it and then attach it to my torque wrench. i just used a 10mm open faced wrench and tightened it up..used the goodntight method. So any newbie can do it. i then took the car out for the test.
WOW! What a difference the blowfish shifter bracket makes. I used a 1/2 tank of gas real quick because of spirited driving. Felt like a whole new car, especially because I was not experiencing nibble, lockouts or any other shifter problem....great confidence builder driving with the new bracket. Overall, it was a great day for me and I highly recommend it to anyone with the stock shifter, even newbies. Thanks to Steve at blowfish racing.
VWGTI123
2012 PW #2558
124
0
13Boss said:
Got ExtraCare ESP for 8 years or 125K miles for $1395.
I think it is a decent deal.
is that for an additional 8 years? was through Ford or through a 3rd party? Thanks
cobrarob
11 Shelby GT500
555
131
new york
Ordered the Ford wheel hub w/arp f/r studs
Heard something different on the way home from
LimeRock on Mon...
A0E100A0-0230-49AF-A724-759C2F71C344.mp4
https://youtu.be/xZDdWU-J5-A
302 Hi Pro
2,009
441
Southeast
I think you got a great deal as it's just a tad over Dealer cost. Ford ExtraCar ESP is one of the best Extended Service Contracts in the industry, with no fine print on the contract.
All ESP plans start coverage from the vehicles original Delivery Date.
This information is for anyone who has purchased a previously owned Boss 302, you can purchase a Ford ESP "New Car" Plan anytime within the first 36 Months or 36,000 Mile period beginning with the Original new car Delivey Date. All based on the vehicles Original Delivery Date to the first retail buyer. (Program Cars maybe different.)
Have fun out there and enjoy your Mustang,
302 Hi Pro
Dave
Grant 302
basic and well known psychic
Missed out on getting them a GHIG Boss sister...for only $29,995. :(
I need to move faster. Back to looking for my project 6. :'(
