What did you do to your Boss 302 or S197 today?
602
539
I re did my Windshield banner. Off with the Ford Racing and on with this one. I want to thank Grant 302 for setting me up with the links to make this. It was a pain to do but it turned out okay. Once the Ford ovals show they will be installed too.
Replaced the stock battery with a lithium - 22 pounds gone. Modified the stock battery tray to lower it for the slightly taller new battery.
steveespo
Lord knows I'm a Voodoo Child
4,063
2,092
Cookeville TN
Adjusted Watts link from Middle upper to Middle lower bolt hole, torque check bolts, brake bleed, fitted G Stream uprights and Watson reinforcements to decklid prior to dropping decklid off at body shop for coat of Wood Brothers Racing Red on top. Should have all buttoned up to leave for VIR Friday morning.
cobrarob
11 Shelby GT500
555
131
new york
Had her at DWW Motorsports for some work.
Installed F/R Ford control arms/bushings/brackets,bumpsteer kit/ABS module/MGW shifter.
Took out Fays and put KB relocate panhardbar back in. Corner balance and weighed 3777 w/ 3/4 tank.
How she sits
680
215
How she sits
Rob,
what are those front control arms like to live with on the street? I know they are not a "street" part, I'm just looking for some real world comparisons....
cobrarob
11 Shelby GT500
555
131
new york
BigTaco said:
Rob,
Hey BigTaco, note I also did the bumpsteer kit...
I only did a 5-10 minute blast when I picked her up, but my initial impression was I heard squeaking and clanking up front(Which doesn't bother me) They said it has to settle in. On the smooth road it was AWESOME but at low speeds pulling into my garage I heard the noises. As for the usual track maintenance,also said for street driving to watch the forward bolt for movement(loosening) and ball joint loosening.
Hopefully this helped. Weather permitting hopefully take her out for a longer cruze.
Fabman
Dances with Racecars
6,593
8,277
Today begins a new secret project....
New shoes today. Giving the Nitto NT555G2 a try to see how I like them. Been a Continental customer for years (street only), but sound like they are discontinuing the DW so decided to switch it up.
Grant 302
basic and well known psychic
Boss got its annual rinse-down. Got an hour drive in.
Then more CTSC graphics for the FakeR.
Just need my TMO banners for the quarter panels..hint, hint ;)
captdistraction said:
No room unfortunately. I really wanted it anywhere but in the passenger compartment. This is what compromise looks like. I'm going to shield the burst valve though so if/when it goes, I won't be treated to a hot oil shower.
When I've seen them installed, they were most frequently in front of the driver strut tower mounted vertically. IIRC, you have remote reservoirs for the JRZs? At least you wouldn't dump it on the tires or headers.
Fabman
6,593
8,277
Your number is 808....?
I wonder how many people besides me and Byron get the reference.....
