Anybody think this gauage pack is a good option to add? Or, are there better gauages out there that need/should be added? The gauage pack might fit better and look the best.
I am reserving judgement on this until I can get more information. I already have a GPS based lap timer and speedometer that I bought for $250. It plugs into a 12V accessory port and velcros to the dash. For engine coolant temp, I use an Aeroforce CN-Series gauge that is mounted in the A/C vent in my GT500 and it cost $250. You can track anything you can read from the OBD II port with that Aeroforce gauge. If the car comes with an oil pressure sender/switch you can pick up oil pressure on the Aeroforce gauge. If not, they sell sensors for less than $100 and you'd have to install that with the FRPP kit as well. The question is does the FRPP gauge pack come with oil pressure sensors or are they already installed in the regular Boss?1BadBoss said:Anybody think this gauage pack is a good option to add? Or, are there better gauages out there that need/should be added? The gauage pack might fit better and look the best.
Not yet, but I would like to at some point. I think the oil temp goes in the oil pan, but I'm not sure on oil pressure. I need to do some more research on that or call Aeroforce.atrain1975 said:Gary - did you end up installing a sensor/sender for oil pressure or any other analog info for your aeroforce? Just wondering how difficult that was / would be.
Thanks!
Alex
So it's already installed then right?cloud9 said:My wing was ordered Monday, showed backordered until next week, then showed up on Friday. Weird.
Mark said:I vote to black vinyl wrap your roof.
Thats freak'in funny right there! javascript:void(0)
