3D Printed S550 Brake Fluid Divorce Bracket
2
6
USA
Hey all, I designed a bracket for those using a GM Clutch reservoir to divorce the clutch fluid from the brake fluid.
Since the angles are not perfect I will post the 3D file later. I can also ship at cost if someone's interested. I printed mine with ASA. I added some pictures.
On another note, how far engaged can the clutch line go over the nipple? I cannot get mine to push on more than the second picture.
2
1
Circle Track
atlanta
Hey all, I designed a bracket for those using a GM Clutch reservoir to divorce the clutch fluid from the kotob-pdf brake fluid.
great work
113
So cal
I printed mine and got the clutch reservoir, will install it soon as i get a chance. How are you guys sealing off the old nipple on the brake master?
39
28
Atlanta
I replaced the reservoir with an auto one from a PP mustang (#FR3Z-2140-B). Ford doesn't sell just the reservoir so you'd need to buy the whole master cylinder unless you can find a used one. I'm sure you can just find a tapered plug to fill the hole and cap it.
484
451
MD
Same. Purchase auto reservoir from local junkyard and second one from Midway mustang
