Can you use the Watson mount with the factory steering wheel?
neema said:Can you use the Watson mount with the factory steering wheel?
steveespo said:A couple questions, I got the Sparco wheel kit from Rehagen, when you remove the airbag and clockspring what gets disabled? Advance Trac?
steveespo said:No I don't think so, I tried to mount my traqmate with a similar bracket and the airbag hub is not symmetrical, when you rotate the steering wheel it will hit.
Grant 302 said:I was meaning to ask if you got that plate for the display. No cage pics yet?
ArizonaGT said:It is going to be 100% weld, I'm glad you mentioned dropping through the floor because I was a little concerned when the builder mentioned that but it makes sense
steveespo said:A little out there but a body in white with cage is like $14000. About how much is the cage work you are doing? When my car was banged up I considered it but the damage wasn't too severe just cosmetic.
Steve
NFSBOSS said:Wow it's hard to see a car I once rode it look like that. I'm sure my next ride is going to be a lot more fun! 8)
I like the photo of the bar behind the dash, something you don't see when the car is all together.
blacksheep-1 said:It's a shame that most racing organizations won't accept chromoly. I understand why because you have to TIG it and it's much easier and user friendly to use mild steel, but you sure can save a ton of weight with CM. Size for size it weighs the same as mild steel but you can use a smaller diameter and/or a thinner wall for the same amount of strength as mild steel. NHRA (as I recall) are the only guys letting people run CM. I just hate the idea of pulling out 400 pounds of weight and then putting 400 pounds of tubing right back in, especially that high in the chassis.
Nice looking cage though, nice work, it's a lot harder than it looks!
steveespo said:Car is coming along very nicely. Cage looks great. .120" DOM tubing?
Steve
