- 873
- 0
Is there a direct bolt in no rigging transmission for the Boss? Where to buy it? If my dealer does not get my transmission right I am considering just gutting this JUNK transmission and clutch.
908ssp said:I've helped install two of these. A few minor teething problems but the feel of shifter alone is worth the change. If your car is NA you might miss the gear ratios of your stock tranny. You might have to put in a 4.11 to get the ratios back to what you're used to but that isn't needed with a SC engine.
if you go with the .62 version it's not that bad had that ratio set in my 96 cobra worked great. A gear swap is easy as well. But you were planning to go with a super charger right? Then the .50 Trans and stock gears would work out greatjeepinocala said:Sounds like alot to go through, right now I just want a bolt in no other changes transmssion.
so with 3.73's and a shift speed of say....8300 the .63 ratio box would be pretty nice in the boss. I think if I go with a T-56 XL I would run 4.30's out back like I did in the cobra when it was NA.908ssp said:I put the 6060 with the 2010 ratios in my SC car I like them a lot. The close ratios of the Boss can't quite be duplicated with an overdrive 5th.
Numbers based on 3.55 rear end and 26” tall tire:
[email protected] MPH/Gear RPM @80mph
TR-3650 OEM gear ratio
1st 3.38 42mph
2nd 2.0 71mph 29mph
3rd 1.32 107mph 36mph
4th 1.0 142mph 35mph
5th 0.675 210mph 2475rpm
TR6060 (stock GT500 2007-2009)
1st 2.97 48mph
2nd 1.78 80mph 32mph
3rd 1.30 109mph 29mph
4th 1.00 142mph 33mph
5th .80 177mph
6th .63 224mph 2250rpm
TR6060 (stock GT500 2010-2012)
1st 2.97 48mph
5th .74 191mph
6th .50 283mph 1875rpm
MT-82
1st 3.66 39mph
2nd 2.43 58mph 32mph
3rd 1.69 84mph 29mph
4th 1.32 107mph 33mph
5th 1.00 142mph 35mph
6th .65 218mph 2375rpm
T-56 Close Ratio Gear Set
1st 2.66 53mph
2nd 1.78 80mph 27mph
5th .74 191mph
T-56 Drag Race Gear Set
1st 2.97 48mph
2nd 2.07 68mph 20mph
3rd 1.43 99mph 31mph
4th 1.00 142mph 43mph
5th .80 177mph
908ssp said:T-56 Close Ratio Gear Set
1st 2.66 53mph
5th .74 191mph
1st 2.97 48mph
5th .80 177mph
NewBossowner said:Did a bunch of research on this because I plan to supercharge and know I will vaporise the transmission. The Tremec T56 magnum with 4.56 gears in the rear end is a very close gearing combo to the Mt 82.
Tremec also has a handy little transmission gear ratio, RPM, speed calculator that will allow you to find speed in gears at different RPM with different tire sizes and such.
jeepinocala said:NewBossowner said:Did a bunch of research on this because I plan to supercharge and know I will vaporise the transmission. The Tremec T56 magnum with 4.56 gears in the rear end is a very close gearing combo to the Mt 82.
I do not think the transmission cant handle the power I believe it shifts like crap.
NewBossowner said:I will be using it to ambush 1,000 HP Vipers and GT40's so all the gear I can get will help. Traction wont be the issue.
908ssp said:NewBossowner said:I will be using it to ambush 1,000 HP Vipers and GT40's so all the gear I can get will help. Traction wont be the issue.
No offense but it sounds to me like you don't have much experience with high torque and HP cars. My buddies 07 has 650rwhp and you have to drive it like you're on ice all the time. One rash move and tires go up in smoke and he's running R compound 295 Nittos. He's running the close ratio T56 with a 3.55 rear gear. He also owns a 2012 Brembo car and there is no comparison the 5.0 motor needs the MT82 the SC motor doesn't and would be a complete waste. The time you spend shifting he would long gone.
