Brake pressure available via CAN?
485
455
MD
Is there any brake pressure data available over CAN? I am trying to setup my display dash for data and wasn't able to get brake pressure.
I am not too knowledgeable in the electrical department for the cars but I am able to get brake pressure using my Race Capture connected via OBD. I think it takes some reverse engineering because I’ve seen it mentioned in the FB group when someone was trying to figure it out using AIM DL
captdistraction
GrumpyRacer
1,954
1,698
Phoenix, Az
what system are you using? If you can manually map channels, try (this is from a 2017)
Channel - CAN ID - Offset (Len) - Formula
Brake Pressure - 125 - 0(2) - x 0.025 / 1 + 0
