Cooked seals on brembo calipers
5,291
4,293
Changing my pads and rotors today and saw that my brembos piston seals look really cooked and the dust shields are broken up and cracked. Is it relatively easy to install a piston seal kit?
Is there a upgraded caliper kit that would use the same discs??
5,291
4,293
Ooops!! just so the stick right above my post!!
Save your money and rebuild them.
We use those calipers racing in the NASA Spec Iron Class and we are only 3 to 5 seconds off of the AI lap times at most tracks, they can handle track days just fine.
Rebuild kits are available from Giro Disk, $48.00 per side. http://www.girodisc.com/Ford_c_29.html
Drill down to Boss 302 and then to Seals & Fluids.
You can rebuild them in your garage, here's a link to video. https://www.youtube.com/watch?v=HCLqUREvKm8
Let us know how it goes!
Doug
6,467
8,398
is it the "seals" or the "dust shields", if it's the seals, depending on the application, they would leak fluid, the dust shields are well....sacrificial
drano38
Wayne
1,130
319
I replaced my dust boots this spring.
Overall a simple process.
The seals are most likely good as blacksheep said.
