S197 3V Fabman's build; How did we get here? Build Thread
6,571
8,232
I'm thinking the $20-30k is the pre-Covid prices. Had a yapping with Terry Fair about it the other day. If you're building to be competitive for something like NASA xT2 / SCCA T-2, you'll probably be slowing down a bit, I ran with them down here at ACS and was 3-5 seconds faster. That said, I guess it's probably the fastest Spec series there is right now.
Since you're turning it into a real race car, you can start out with a salvage title, crappy paint, etc. The pre-made roll cage is under $2000.00...if you can weld you're essentially all in for probably $2200.00 and your time to end up with a real roll cage. If you do your own work, I promise you can come in with a cost of way under $30k including the purchase price of the car. You don't have to run their suspension or big brake kit....stock is fine and then you can always add it to the car as you grow.
I just saw a 2004 C5 with a manual trans with 170k on craigslist for $13k. Perfect starting platform for a race car that you're going to strip out the interior, cage it, etc.
PaddyPrix
728
1,088
San Diego
Yeah, which is more or less the same with an s550 base GT, plus the resale value of the takeoff parts is slightly higher and arguably in higher demand. I'm pretty sure I'm still under $20k. Everybody wants a gt350, but the GT will do just fine if you're focused for the track, perhaps better off with the Coyote vs Voodoo.
6,571
8,232
And there it is.
6,571
8,232
6,571
8,232
5,270
4,270
In a month or two or so we can take bets on Hp numbers. E85 vs 98 octane. The way maritime shipping is totally collapsed right now, my motor will get flown down.
6,571
8,232
It’s probably close, 91 to e85 was only about 12 whp on mine.
it’s the cooling, detonation resistance and low price that makes it worth it to me. Boosted motors benefit way more. It was 100 whp on my blower motor.
5,270
4,270
I am still debating between the two. E85 will mean buying barrels of Ethanol and mixing it myself. Lucky am not a smoker Lol. Our last motors were very close with 93 vs E85. Just mine committed suicide.
6,571
8,232
Mixing? are you buying straight ethanol and mixing gasoline into it?
5,270
4,270
That would be the only way I can get E85.... which is why I will probably go with 98. In any case from the logs, the 93 was decent down here as timing was advancing fine with no hint of detonation.
6,571
8,232
Here 100 octane is over $10/gallon while e85 is still $3.50/gallon and I can buy it at the pump so it makes sense for me.
6,571
8,232
5,270
4,270
If I was in the neighborhood, would be happy to give a hand. But am nearly 6000 miles away so no amount of pizza would help get me closer.. We found that dropping the engine/tranny together on a lift was the simplest least hassle way to go.. We have had to do it a lot recently.......... :ohdamn:.
Hoping that the next engine stays in for a long, long time.
6,571
8,232
Mine is a little more complicated than that, but I'll get it done.
6,571
8,232
