- Thread starter
- #2,781
- 6,580
- 8,242
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Not yet....but there's still time. Thunderhill Sunday to test. Stay tuned!Actually your was not dead so thats no really applicable!
Guess we have to stock up on toilet paper again.they dont expect this issue to be solved and back to normal until 2027
Project cambered rear end by #CORTEXRACING up for testing Sunday at Thunderhill.
I installed both at the same time, but the watts allows me to move the roll center around to alter the handling and that’s a very valuable tool.Do you have any sense of whether it was the Watts Link or the Torque Arm that contributed the most improvement in your handling?
I was 300’s out back, I went to 350’s with the cambered rear end and that may go up by the time we’re done testing today.No rear bar? What ballpark F/R spring rates are you at?
DaveW
I put my 18mm rear bar on at the last race and took it right back off. It made the car feel very nervous. I have a cortex racing rear bar at the shop I’m going to try with this cambered rear end. I wanted to change one thing at a time.No rear bar? What ballpark F/R spring rates are you at?
DaveW
There is a LOT more speed in this car. I didn't even get a chance to start dialing it in before the rain came.Great stuff! glad to hear the affect was near instant. So thats another thing for the Xmas list... well maybe in 2025 Lol!
Watt?I can tell you it wasn't the Watts... lol
j/k
Just Butt Dyno and stop watch. Both said major improvement.Do you have any data to compare cornering forces and speeds? Would be super interesting to see what the cambered rear changed.
Did you change your rear gear?? I was thinking about putting in a 3.55Just Butt Dyno and stop watch. Both said major improvement.
This was a quick test to see how close the setup is and if we got the new ring and pinion installed correctly.
I knew the setup would be tight and need some tweaking but it was really closer than I thought.
It rained so I didn't get much time on the track but it was totally worth going and the rear end was totally worth buying. Definitely cornered way harder.
I stuck with the 4:10'sDid you change your rear gear?? I was thinking about putting in a 3.55
