- Thread starter
- #1,081
Fabman
Dances with Racecars
- 6,620
- 8,308
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Front bar was in the middle hole w/500's and I went full soft when I put the 600's in.FWIW I run my wing pretty close to flat. I'd bet AJ's wing is even more efficient than my APR one, as well.
You could try stiffening your rear bar, but that may affect traction when on-power not in a straight line, depends how good your diff is.
Alternately (or cumulatively), can you soften your front bar at all?
I run 600/325 now so that's pretty darn close to my setup--although in that Laguna video I was on 800/275.
Its probably just too much wing, like I said, I had no way of checking wing angle at the track so it was a guess. Just the same I will go over every thing in excruciating detail as is my usual style.
