213
180
3-5 Years
Columbia, TN
Hi All, I'm running MM Caster/Camber plates and their front track pack springs on Koni Yellows with an Eibach front anti-rollbar. Rather stiff setup. I was getting ready to install my bump steer kit and found the upper strut mount bearing blown up. Is this from a misalignment during initial install of the MM plates or are these things just weak junk and there are better options? I will say I have no clue if these are the original mounts or not as I'm not the original owner, but I'm willing to bet they are with all 110,000 miles on them. I suppose I should have used new ones when I installed all of the other suspension components. So maybe the age/mileage plays a part in this failure? Thoughts?
Just found Ford Performance has an "upgraded" unit M-18183-C
Anyone have any experience using this with an aftermarket Caster Camber Plate?
The GT500 (and 2005-2010 Mustang GT) strut bearings are different than the 2011-2014 Mustang GT. The MM plates (and if I recall correctly the struts) are also different between the two.
I actually have the GT500 parts* on my 2011 GT, primarily because it was convenient for me at the time. No complaints here, but I have less than 10k miles on them and cannot really speak to whether they are better than the 2011-2014 GT parts.
*MM plates with GT500 strut bearings parts, Koni yellows, and H&R Race springs
8,295
Unless they changed the rules, the SCCA does not allow bearings in the struts, they were all over this a few years ago at the runoffs, in the touring class. Which is weird because I'm unaware of any ( legal) aftermarket
cam/cas plates that do not use them.
Hopefully they've changed it, but you might check.
213
180
3-5 Years
Columbia, TN
Ok, so I just gotta stick with the stock setup and see how it goes. The guys at MM said if the bearing is blown up like in my pictures it was from a misaligned install. I'll let you all know how it goes! Thanks
