Well, time to take the engine out again!
Grant 302
basic and well known psychic
To be honest, i don't think I would have made it throught the last endurance race with out A/C Is was about 30 deg C (86F). Dont have a cool suit... I used to race in the summer (Dec, Jan and Feb down here). then we would see temps up to 38C (100F).
Now that I am sticking more to one series, I have thought about taking out the A/C. I am sure the engine temps would drop with out the A/C...
Coolsuit tyme?
Mad Hatter
Gotta go Faster
5,263
4,261
Santiago, Chile
heads are off and cylinders look good so far... fingers crossed but nothing very scary looking....
Scared to see how much ye Olde Cool Suit costs
Grant 302
Heads are off and cylinders look good so far... fingers crossed but nothing scary looking....
So far!
Great! Hopefully, it's mostly heavier carbon buildup causing poor ring sealing or something like that. Post pics when you can!
Would this be a help??
https://www.summitracing.com/int/parts/fms-m-8c607-msvt
Fan from the 2013+ GT500 is very affordable.
It's reported to be better by several members. Hard to quantify, but it has helped some cars with persistent overheating issues.
Mad Hatter
Gotta go Faster
5,263
4,261
Santiago, Chile
Hmm.... take the A/C out and save weight... then add a cooler system... Can you keep beer in those things for after??
Mad Hatter
Gotta go Faster
5,263
4,261
Santiago, Chile
With respect to running with the AC on, do they allow you to run on the tracks in Chile with the windows up?
Yes we can run with the windows half open.... Usually always run with the AC off, right after the checkered flag I hit the max air button. Only in the Enduro race did I have it going while racing.
Mad Hatter
Gotta go Faster
5,263
4,261
Santiago, Chile
Hmmm.... are my calculations right? Take out all the A/C and save 20 lbs...... Add a cool suit and add 40 lbs???
Grant 302
Sounds about right. Maybe a bit more savings in the A/C than that.
Maybe it makes more sense to just catch the condensate water instead of draining it when you put it that way.
Mad Hatter
Gotta go Faster
5,263
4,261
Santiago, Chile
Well jsut got back form the shop... Everything los like STD with some ragged edges on the exhaust valves and a broken ring on number 8 cylinder but no deep scratchs or wear.
Piston with broken ring......
All the guts on the table
Crank looks ok, ugly rough oiling holes need a bit of tender loving care.
Nothing scary!!
Nice and shiny!
Worn bearings
Valves with broken ring
All the other valves...
My mecanics already want to port the heads. like the Intakes but no the exhaust side.
Golden intakes thanks to MMT!
Intake and exhaust valves
Thats all I had time for tonight!!
Will be adding oil squiters... does any one have the part number?? Have only seen then in kit form. Do you think its time for new valves???
Grant 302
You did good there. Smart to do the compression test and subsequent tear down. You saved the engine for sure.
Not 100% sure on the squirter part numbers. I came up with
BR3Z 6K868-D as the latest. I'd call FP when you get a chance or confirm elsewhere.
At the very least, I'd polish all the exhaust port parts that built-up heavy carbon deposits. Easy to see all that crap by the seat. Could you take more pics later of both sides of int and ex ports? Should be telling on where material should come out, IMO. Get as close as you can with the camera focus and use flash if you have to. I do see where the intake seat transition and bowl could be cleaned up a bit. But I wouldn't want to add intake volume and take away port velocity or the OEM CNC roughness. Not for a high RPM engine, IMO. Maybe if you had somebody local with a good CNC profile already programmed, but I doubt you have access to one.
Mad Hatter
Gotta go Faster
5,263
4,261
Santiago, Chile
Grant will do! My Builder want to add a little epoxy to the Intake to smooth out the air to the valve... but I feel like this might not be the best idea in the world......
Coz, no oddly enough the oil in the catch can did not increase... (only have on on the passenger side). And the car did not smoke.... Just a general loss of power made me want to check the compression. Even the logs were almost the same withthe same MAF.. I thought the MAF would go down with loss in compression...... But my Boss has always been a oil consumer since it was new new.
Mad Hatter
Gotta go Faster
5,263
4,261
Santiago, Chile
Very happy to see nothing major!! Now to damage the credit card in Summit, Tasca etc...
With luck the parts will arrive middle of next week and we can start building.
ArizonaBOSS
Because racecar.
8,730
2,734
Arizona, USA
@Mad Hatter I tagged you in an old thread of mine on FB when I was rebuilding my engine. It's fairly easy (albeit time-consuming) to clean all of that orange crap off.
Grant 302
That's not the worst idea either. IF (big if) you were going to 'realign' the whole intake port, epoxy one side and port the other would be the way to go. But only if someone is very well versed in these heads would I allow them to do it. Everybody has their own theories about raising or lowering ports and short side profiles, etc. Without radically changing the flow strategy, I'd leave the general alignment alone and only 'fix' the areas that are difficult for the CNC tooling to get to or blend from work 'joined' from both sides of the port.
I see the exhaust side as relatively easy to improve with 'traditional' methods. Almost anything done without hogging out material will improve flow and reduce pumping losses. Polishing will also help maintain that flow until next service.
Yes, very happy for you on that note! Considering your use and the Enduro, I do think things held up pretty well.
