Dark Horse
2012 BOSS 302 LS 541
cloud9 said:
Is that an aftermarket mirror? If so, would you mind providing some information on it?
cloud9 said:
It's the Homelink mirror that comes on the premium GT. 3 programmable garage openers, auto dim, compass and temp. Since the Boss has the temp feature already you can get it without it for $50 less and no wire through the firewall to a sensor in the grille. I ordered it from the dealer for $450 installed.Dark Horse said:Is that an aftermarket mirror? If so, would you mind providing some information on it?
Wow that is light. Still for me to only save another 7.5 lbs I'm good with the fiberglass. The body man said it was the best looking fiberglass hood he's seen and won't require much prep at all. They were all commenting on how light it was so yours must be like a feather ;DJza1736 said:My CF hood weighs in at 12.4 pounds. It is so light
cloud9 said:It's the Homelink mirror that comes on the premium GT. 3 programmable garage openers, auto dim, compass and temp. Since the Boss has the temp feature already you can get it without it for $50 less and no wire through the firewall to a sensor in the grille. I ordered it from the dealer for $450 installed.Dark Horse said:Is that an aftermarket mirror? If so, would you mind providing some information on it?
We're painting the underside orange. The topside will be like the original 302S in gloss black with the pinstripe like our stock hood decals. I went with four hoodpins, and we're going to eliminate the hood latch and block that area with some aluminum to keep all the air going through the radiator.5 DOT 0 said:30 degrees above normal??? Yikes. It's supposed to be mid 50's here but I can't drive today.
Looks good. Are you going to paint the underside of the hood as well?
cloud9 said:Wow that is light. Still for me to only save another 7.5 lbs I'm good with the fiberglass. The body man said it was the best looking fiberglass hood he's seen and won't require much prep at all. They were all commenting on how light it was so yours must be like a feather ;DJza1736 said:My CF hood weighs in at 12.4 pounds. It is so light
cloud9 said:Body shop just called and asked if I wanted to install a washer nozzle relocation kit to the wipers or just cap them off. Looks like LMR sells a kit for $60. Opinions? It's not like I drive it in the conditions that usually require the squirters, but then again, hate to get caught and can't see.....
cloud9 said:Do you have any pics? What did he attach them to?
