5 DOT 0 said:And the correct answer is I'm at a shop having them installed right now.
Rick - WHat did you do to lower the front end ? Car looks great.
It's top secret. Ford Racing will make an announcement about it soon.PeteInCT said:Rick - WHat did you do to lower the front end ? Car looks great.
5 DOT 0 said:Roush side splitters installed.
None. Very simple installation as long as you have your car up high enough to get your drill under the sides to drill five holes per side.BossJockey said:5 DOT 0 said:Roush side splitters installed.
I'm thinking about doing these. I assume there were no issues with the side pipes?
Yes they are the Ford Racing wheels. CJ Pony has one of the best prices on them.Tflong24 said:5 DOT O, im sure it has been asked before, but where did you get your wheels. How much and what size? Are they GT500 replicas or Ford Racing? Thanks
5 DOT 0 said:Pete nice work on the grill and I agree with you that a bar grill will flow more air. Kendall posted this on another forum and it's what I'm planning on doing (this week). It's the grill from the Cobra Jet drag car. The specs state it will not fit with a stock hood and one of Kendall's friends has it mounted on a LS with a 302S hood. One bonus for me is the surround is painted white which ties in nicely with the white striped cars. This would be an easy swap for use on the track and then install the stock grill for the street. Or just run it all the time...
cloud9 said:Body shop just called and asked if I wanted to install a washer nozzle relocation kit to the wipers or just cap them off. Looks like LMR sells a kit for $60. Opinions? It's not like I drive it in the conditions that usually require the squirters, but then again, hate to get caught and can't see.....
cloud9 said:A friend of mine came over today and helped me finish up my roll bar. It came out really good. He has a brand new Sparco race seat that I'm going to buy from him since he decided not to put one on his passenger side. We'll work on installing the harness lap belt and sub belt eye bolts next. I may try to get it in for the hood next week if the weather cooperates. We got about an inch of snow yesterday but it's mostly gone from the main streets and they didn't have to salt. Here are some pics. Sorry about the low light, but it's trapped inside the garage for now......
Uploaded with ImageShack.us
Nice...
Thanks for the reply.
Lee.
Good call. I decided to do just that. I canceled the order for the nozzle relocation kit and just pulled the bottle along with the gallon of washer fluid I thought about it and realized I might have used the washer once, maybe twice all year. So I probably dropped 8-10 lbs and improved the flow path on the passenger side brake cooling hose2012YellowBoss said:cloud9 said:Body shop just called and asked if I wanted to install a washer nozzle relocation kit to the wipers or just cap them off. Looks like LMR sells a kit for $60. Opinions? It's not like I drive it in the conditions that usually require the squirters, but then again, hate to get caught and can't see.....
Should have skipped them, that way you can get rid of the "filled for life" washer bottle. I am sure that weights more then the hood!
cloud9 said:Good call. I decided to do just that. I canceled the order for the nozzle relocation kit and just pulled the bottle along with the gallon of washer fluid I thought about it and realized I might have used the washer once, maybe twice all year. So I probably dropped 8-10 lbs and improved the flow path on the passenger side brake cooling hose
