- 1,788
- 30
pa93cobra said:jmboss,
Could you please check on the following:
Order #: 0206
Dealer# F16513
Thanks!!!
As of the March 20th update, your car is "In Order Processing" - "Unscheduled- Material Hold".
Order #: 0206
Dealer# F16513
Thanks!!!
SouthernBoss302 said:JMBBOSS302 - can you give me an update on VIN # 1ZVBP8CU8D5210675? Your last update had a build date of today April 2nd. Wonder if it is going to start today or not.
jmbboss302 said:batman48195 said:Hi Mark,
Any update on mine? 1zvbp8cu8d5200650
I looked at the window sticker online and the date at the bottom changed to 3/29/2012, so I was thinking maybe they made some status update on mine.
Thanks,
Brian
From the March 20th update:
Awaiting Shipment - Returned to Plant (Autoport Limited ) - Flat Rock, MI - Mar-20-2012, 06:51 ET
jmbboss302 said:SouthernBoss302 said:JMBBOSS302 - can you give me an update on VIN # 1ZVBP8CU8D5210675? Your last update had a build date of today April 2nd. Wonder if it is going to start today or not.
Your car has been pushed back as of March 27th.:
In Order Processing - Scheduled to Week (Week -of May-14-2012) - Autoalliance International Inc, MI - Mar-27-2012
2012boss said:i've seen that same change on a couple of LS models. Not sure why unless they built a generic gap to allowing fixing all the existing units
RoushF150 said:It's a new week JMB. Time to start bugging you again.
Any change on 1ZVBP8CU1D5201686?
Ucode13SBY said:Can you run an updated status on 1ZVBP8CU6D5207225?
SouthernBoss302 said:jmbboss302 said:SouthernBoss302 said:JMBBOSS302 - can you give me an update on VIN # 1ZVBP8CU8D5210675? Your last update had a build date of today April 2nd. Wonder if it is going to start today or not.
Is this Order #J400 and Dealer Code #F21717? Can you verify? If so this is a 6 week slip. Wonder what would have caused this?
BossFred said:JMBBOSS302,
could you check the status of 1ZVBP8CU5D5202551 ?
It is suppossed to be already built and shipped.
Thanks,
Fred
1DAAT said:Do these in transit statuses mean that the striping issue has been resolved?
jmbboss302 said:BossFred said:JMBBOSS302,
Thanks,
Fred
It was Produced March 2nd. Here's its status:
In Transit - Recieved-Rail (Auto Warehousing) - Ramp 51, Auto Alliance, Mi - Mar-5-2012, 05:15 ET
Thanks for the update.
