S197 3V Fabman's build; How did we get here? Build Thread
6,559
8,213
6,559
8,213
6,559
8,213
My alter ego....SCCA vs. NASA.
6,559
8,213
Lots done, lots more to go.
Gonna be another 7 day week…..how many is that in a row now...? I seem to have lost count.1f61e.png
#SometimesIthinkIlivehere
6,559
8,213
Got a lot done today, Will do more tomorrow.
I swapped out my Moroso degas tank for a Ford Racing unit that I got from @Albino500
(That guy has everything in that shed of his……its like the Fort Knox of Race Car Parts)
The Ford Racing tank takes a regular radiator cap unlike like the stock bottle/Moroso tank which only accepts a factory 16 psi cap.
Regular caps can be had in a variety of pressure ratings. Back in the day we ran 22 psi caps on our stock cars.
This week I was able to obtain a 30# cap from Summit, so that would be...more. So more it is. I like more.
I welded in a bung for an A/N hose that bleeds air from the top of the water neck.
I also welded up the purge line that bleeds air from the top of the radiator and re drilled it 1/8" to bleed air, but slow the flow of hot water.
Once installed I ran the electric water pump with the motor off and let it bleed for a few minutes.
Air pockets don't happen like they do with the stock setup....just fill the system and it self bleeds. Boom-done.
I also don't use a thermostat. I just turn the toggle off on the electric water pump and warm the motor.
As soon a I see the temp gauge start to move I flick it on. Instant thermostat and no air pockets.
I also ran an A/N line to a catch can as per NASA/SCCA rules. (I used a Nalgene container)
A hose clamp under the cap keeps it from shooting out of the catch can in the unlikely event that water somehow pushes past the 30# cap.
I'll polish up the aluminum tank sometime later to make it look pretty, but for now this is going to have to be good enough.
Plenty more to be done still.
6,559
8,213
I also installed a proportioning valve to limit pressure to the front brakes .
I have way too much front brake bias and it's killing my front tires not to mention it makes braking on turn entry a crap shoot and that sucks.
I installed a couple pressure gauges, one front and one rear caliper to see what the pressure delta is.
When I bleed the brakes I'll use the new valve to lower front brake pressure by 200# to start. (Where is my pedal pumper when I need one?)
I'll use the other valve I previously installed in the rear to fine tune the balance on track as I have a knob inside the car that controls it via flexible cable.
(See earlier post with pics and details on how I did this)
I put the front valve right above the ABS delete block so its accessible from under the hood and again, I'll fine tune the rear with the knob inside the car while on track.
There is no ABS since the Coyote Control pack doesn't talk to the 3V electronics so this is my idea of a work around. Just an ABS delete block and a couple pressure valves for fine tuning.
We'll see how well that works next week at Laguna....wish me luck.
IMG_4981.jpgIMG_4982.jpgIMG_4974.jpgIMG_4979.jpgIMG_4975.jpg274738733_326445142784276_893559289975821014_n.jpg
6,559
8,213
Some new pieces from CorteX Racing.
Competition sway bar, trailing arms and drop brackets.
Looking to pick up some mid corner speed.
Another 12 hour day, I'm pooped. I'll finish up stuff this coming week.
6,559
8,213
Cortex competition sway bar? Awesome!
*opens wallet*
Sigh.
Well we'll see...I don't normally like a rear sway bar but Filip swears by it and both @ArizonaBOSS and @captdistraction run these so I thought I'd give it a try.
This setup adds the sway bar, raises the rear roll center, flattens out the trailing arms a couple degrees and adds 50# of spring rate.
All things I don't want to do....but, hey...Filip is a smart guy so I'm taking his advise. If I don't like it I can change it back easily enough, but its definitely smart to give it a try.
ChrisM
Mostly harmless.
1,180
1,420
South Carolina
That was my actual question behind the snark. No rear sway was definitely an improvement on mine but I know @ArizonaBOSS runs this and the number of people who can argue with Filip is probably in the single digits. Definitely interested to hear your thoughts on this once you've tested it.
Also want to say that I really appreciate the level of detail in all your posts. Any time I have a question I just go back through this thread and you've already done it and tested it in real time instead of just relying on others (which is what I do...).
6,559
8,213
Happy to help....if nothing else you can learn from my mistakes.
1,186
2,194
Seeing your pictures gets my “impatient meter” pegged at 10!!! I have one of these sway bars coming with the coilovers. You mention the trailing arms being more level - I assume from the drop brackets having a higher hole than what you had before?
6,559
8,213
Yes I was using the maximum Motorsports brackets that have 3 holes very close together. The hole I used is right between the two holes on the cortex bracket so the angle is 2.5 degrees instead of 4*.
Frank.JD.Perez
FJD Performance
314
490
Pleasanton/Hayward, CA
i know where to get the stickers, im just saying i dont have any
fabman also had me do a lightweight leg day sesh yesterday with those brakes
6,559
8,213
Just think, some people pay a gym membership to do leg presses....you got to do that for free!
Plus....you are one of the damn few people to sit in that seat so...that's gotta be worth something.
6,559
8,213
