Thanks for the photos and welcome to BMO.mycroft said:I ordered and received mine as well. They appear to be K springs in the rear (same part number). Fronts are in fact unique.
I think the problem with the K is they lower the car too much in the front which throws off the geometry. In the rear there's an easy solution using relocation brackets so it's not as big of a deal. I suspect the T springs split the difference between the P and K relative to lowering the car and might be closer to stock relative to spring rate. With that said the P springs work fine for a nice compromise between the street and track and don't slam the car.bluemax said:I have been holding off on doing the suspension mods until the "T" springs came out, now I am curious if the "P" springs isn't the way to go...
I thought the "K" spring lowered the car too much. I know this is just the rear that the new kit is using, but now I wonder why they selected the "K" rear over the "P" rear.
So, I guess I will now wait on some of you to get them installed and checked out.
NFSBOSS said:I think the problem with the K is they lower the car too much in the front which throws off the geometry. In the rear there's an easy solution using relocation brackets so it's not as big of a deal. I suspect the T springs split the difference between the P and K relative to lowering the car and might be closer to stock relative to spring rate. With that said the P springs work fine for a nice compromise between the street and track and don't slam the car.
That looks like a good plan. I'd put the P front springs on the car you're going to track the most.Grant 302 said:I did make the guess that the kit could have comprised of P fronts and K rears, and that should work great for a square setup. I've been considering doing that on the GT. But with the smaller front tires, I'm pretty sure that the T springs will be a little softer than P springs for use on an otherwise stock Boss. It would be nice to know the actual rates though...
What I think I'm going to do is buy a 'T' kit and put the K's on the rear of the GT and put P rears and the T fronts on the Boss.
NFSBOSS said:That looks like a good plan. I'd put the P front springs on the car you're going to track the most.
The price of the kit does sound a bit more reasonable since they're adding the bumpstops too.Grant 302 said:Maybe it's just a front set of Ps with a rear set of Ks...
I hope somebody gets a set of these to Vorshlag for testing. I'm sure FR isn't releasing specs on the rates...
I'll probably get a set as soon as they're available from other vendors for a more reasonable price like $240-250.
NFSBOSS said:Just by change I met a guy with a 2012 Boss that installed the T springs on his car. I have the P springs on mine and the front looked about the same, possibly lower, and the rear looked a lot lower. I looked very good but no comments on how it rides since he just installed them. Maybe he'll join the forum and share his opinion.
LOL It's looks just like my car but about a 1/2" lower in the rear.colticus said:No pics? WTF, youre slacking.
BadPony said:I am having the T springs installed tomorrow, along with the Ford racing adjustable panhard bar and LCA relocation brackets. I will post pictures and my driving impresssions as soon as I can.
Excellent Choice on the TSW's Way lighter than Stock. Had them on my 13' Track Pack GT and they were great....mardis said:Those that guessed TSW's are correct. I went with the stock sizes...19 X 9.5 for the rear and 19 X 9.0 for the front.
I re-mounted the stock Pirelli's for now.
I reuse them....just use blue locktite.max5ive0 said:Okay, so when you do these mods do you replace all fasteners? I guess the services manual states these fasteners should not be reused. How do you all feel about that?
