Fabman
Dances with Racecars
- 6,718
- 8,569
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Very cool!Made a little more progress today. Got the passenger front on. With both fronts tested for fit, I went ahead and fully welded it on. Might have gone a bit overboard with the welds, but at least I know it’s not going to move. Ha
View attachment 84732View attachment 84733
for the rears, I am using this plug behind the seats and before the rear seat shelf. I thought about tucking into the corner a bit more, but the floor underneath has some brackets I didn’t want to mess with.
To enlarge this hole, I made a template out of wood and hot glued it to the floor. Then used a hole saw to cut the 2.75in hole for the mounting tube.
View attachment 84731View attachment 84730
easy peasy. Underneath of floor will have a 3/16in thick steel plate welded to the floor. Then tube welded to that. Still waiting on the plate.
in the meantime, I fab’d up this bracket for the top. Reinforced with two gussets - one on each side.
