My motor blew up......now what?
6,401
8,295
The reason I mentioned the valve springs is if you are using the old heads. Now is the time to replace the springs since it's all apart.
These engines are pretty remarkable as long as you maintain them, even the timing chains are not much of an issue, but I have seen a few broken valve springs and that can be catastrophic.
Fabman
Dances with Racecars
6,553
8,204
I did take your advice and order the crank scraper. Still waiting on that. The owner's wife answered the phone when I called and then yells out to husband who's in the garage working. Pretty funny. Talk about a "mom and pop" business lol.
Don’t forget their windage tray, they work together.
Fabman
6,553
8,204
What would you recommend?
Gen 2 heads use the same spring as the boss 302 which are adequate for cams with stock or near stock lift. The L&M “intake only” cams that I and many others here on TMO (and beyond) run have stock lift and increased duration. I used these stock springs in competition at 8000+ rpm all year without issue. I also change them between seasons as a safety precaution. Valve springs are cheaper than motors.
I bought a set of the 302R springs but then decided I wanted a bit more rate so I went with Livernois. They are between the 302R and PAC springs. PAC springs were really pricey. Even went with new followers and GT350 rollers
Fabman
6,553
8,204
The strategy for going with minimal spring pressure and smaller cam profiles is that it doesn’t put excess stress on the valve train and VCT. The higher the stresses the lower the reliability. The ideal spring pressure is just enough to control the valve at the desired RPM . No more, no less. I do not know what the psi differences are of the various springs are but the decision was to stay with the boss 302 springs that worked so well last year. Let’s hope they work just as well in 2022. Stay tuned.
Fabman
6,553
8,204
From the images I've seen of the included part number, the GT500 windage tray is the early coyote part.
Yeah I would really suggest getting the proper windage tray that goes with the scraper.
Fabman
6,553
8,204
The other side has oil catchers that funnel the oil down through the screen so it can’t splash back up on the crank.
Fabman
6,553
8,204
Here is the flip side:
Oil control is the key to making these motors live.
I've been checking out some scraper pics that JeffV8 sent me. I also was just going to use the GT500 pan but after seeing all the modifications that Kevin makes I am now wondering if I should have sucked it up and invested in that as well. It took a month to get my scraper but it may be worth it in the long run.
Fabman
6,553
8,204
Oil is the life blood of an engine...anything you can do to improve oil control is worth whatever it costs.
Whats a blown up motor cost?
Pans, pumps, pans etc. are cheap insurance in my book.
1,289
1,113
Philly Metro Area
I apologize for my ignorance up front but I'm not getting the concept.
I always thought that getting the oil off the crank would help reduce horsepower loss. But how does it help reduce the chance of a blown engine?
Can the amount of oil that would otherwise remain up in the crank exceed 8 fluid ounces? Even a pint? With a larger capacity & baffled oil pan, how does that make a difference?
