Seperate clutch fluid reservoir
Fabman
Dances with Racecars
6,553
8,204
Mad Hatter
Gotta go Faster
5,247
4,235
Santiago, Chile
Once the cluch reservior is seperated from the hot brake fluid, it would be nice to have a finned alloy brake fluid reservior..... hint hint..... :)
Fabman
6,553
8,204
I got enough to build already....Every. Damn. Day.
Fabman
6,553
8,204
Fabman
6,553
8,204
This was a cheap fix...thank you everybody for the insights.
I'm going to do the GM reservoir mod (expecting the loss of a few RWHP with a GM part under the hood :D) in couple weeks, when I replace my master cylinder. My RTX clutch 'feel' has been disappointing since I replaced it last year. Very high engagement, jumpy, noisy and vibration in 1st gear. I read post from another GT500 driver that had some similar symptoms and replaced the master and most of his issue went away. Hoping for the same results with a fairly inexpensive fix. Plus, I figured I'd get the separate reservoir taken care of for a few extra bucks. I'll report back in a few weeks.
Fabman
6,553
8,204
And.....there it is.
The 05-08 reservoir is the same for auto and stick.
The little nippie is just smashed shut for the auto.
Thank you all for the tip.
Fabman
6,553
8,204
On a side note, I don't know if anybody else has noticed, but on both sides of the GM reservoir it has this embossed for some reason:
Fabman
6,553
8,204
Grant 302
basic and well known psychic
Fabman
6,553
8,204
Fabman
6,553
8,204
racer47
Still winning after 30+ years
392
497
SE WI
Haha. I installed the gm resivior a few months ago, but i checked my oil last sat and saw that "***" on there and laughed.
I put a sweat band/resivior cover/leak absorber over it.
