- 6,565
- 8,226
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
Sold...ordering now. Thanks for the help!it is, slips on just like stock.
I got enough to build already....Every. Damn. Day.Once the cluch reservior is seperated from the hot brake fluid, it would be nice to have a finned alloy brake fluid reservior..... hint hint.....
I can manage the bracket...Your welcome Fabman. I made the bracket out of ABS, shaped and bent it to for that area.View attachment 2172
I bought the auto trans brake fluid reservoir which has no plug for the clutch. And then the clutch hose does plug in perfectly.I have the same one,but never got around to installing. What did you use to cap the stock reservoir nipple , and did the stock hose plug right into this one ?
Probably to let ford owners know that it was a Chevy part.Or a special message to Ford owners using GM products?
And.....there it is.
The 05-08 reservoir is the same for auto and stick.
The little nippie is just smashed shut for the auto.
Thank you all for the tip.
MAX...?Got your nipple pinched? Must have hurt!
Would have been more obvious after/under the 'MAX' label.
Lost me...As opposed to Minimum F_ _.
