- Thread starter
- #41
- 206
- 30
blacksheep-1 said:That's not roll...this is roll... (I guess) on a front engine, nose heavy car, you basically give up the center of the corner a little so you can get on the gas earlier, so to give the car forward bite you run a lot of roll. To do that you have to get those rear tires planted. You also want to keep the nose supported , basically , you have to play to the car's strengths, which isn't the center of the corner. It's getting in, and getting out. The last pic (with the 275 x18 continentals, looks a lot like your car, and you can plainly see the "piano wire" rear bar.![]()
Ok you definitely have me beat haha. Tell me more about the piano wire rear bar. I assume that means you don't like a stiff rear bar?
