What ‘R’ you doing steveespo
349
182
US
Omg- did someone forget to tighten your seat bolts ? Lol you were in a rocking chair in there! Might need to check that out!
Sweet ride!!
Sent from my LG-H932 using Tapatalk
steveespo
Lord knows I'm a Voodoo Child
4,063
2,088
Cookeville TN
Today’s update from the track. The Full tilt boogie differential cooler setup works really well. Without it I would be at 283 degrees F in 15 minutes, 4 minutes later (2 laps) it would be 300+. Today running 8 lap sessions at Road America (20 minutes) the temps never went above 235 deg F. Here is my particular experience though, I wired it up per the instructions and neither the temp control or bypass circuit would function. After checking all the connections and power to each wire I ran out of time and decided to make it manual operation off of a dash mounted switch, controlling a single pole 30amp relay with direct chassis ground for both pump and fan pack. Works like a charm.
steveespo
4,063
2,088
Cookeville TN
Any pictures from the diff cooler install? Interested in doing this as well. I’ll see you at the Chin Summit Point event in a few weeks.
Nice. I think the stock GT350 diff cooler needs a fan.
