What did you do to your Boss 302 or S197 today?
GB899
NO REGRETS
603
782
Nebraska
Re: What did you do to your boss today?
I bought the blue lady a new set of shoes... they arrived today..
Ford racing 18x9.5 GT500 convertible rims with Hankook Ventus R-sr
285/35zr18...
I can't wait to go play... thanks Bill...
ArizonaBOSS
Because racecar.
8,736
2,747
Arizona, USA
modernbeat said:
Move the mufflers further back, under the fuel tank. A little bit quieter and the sound is more base, less trill.
http://vorshlag.smugmug.com/Projects/Vorshlag-2011-Mustang-GT-build/i-tBL5JbZ/1/M/_DSC3239-M.jpg[/im]
[/quote]
Is this the "Rev 2" design on Terry's car?
I might go there if I get the urge for some "extreme" weight savings. Love the way the Roush exhaust sounds w/ a catless X right now.
Loaded up the trunk with implements if destruction for an early departure tomorrow. Will be meeting Mustangs Across America in Dallas on Sunday enroute to Charlotte!
1,948
2,103
ArizonaBOSS said:
Just had 4 sets of those delivered today. Looks like they got cleaned out this week, glad I ordered when I did.
I really dig the spring rate info for the tires, now I can match them all up in pretty close sets.
Yes I only got 2 sets, wish I'd got more -- went to order yesterday and the 285's are sold out. They still have the 305's.......
buland
One of the rare Boss LS in Switzerland
finished the head unit change. incredible improvement of sound also without a subwoofer or an amp.
preparing the harness
Prepare the metra dash kit
install the mic from the handsfree phone call
remove the stock head unit
install the new head unit
change the display color to ghig ;-)
install the one touch turn signal module
washed an detailed the beauty
I let the neighborhood kids wash most of the road grime from a wet 1K road trip to TWS. They couldn't reach the roof, and missed about 1/4 of the car. But it is improved :)
Sent from my DROID4 using Tapatalk
Nice buland. If you haven't done so changing out the door speakers is easy to do and makes a noticeable difference in sound quality.
buland
hi rick
I've change all 4 speakers last weekend. i forgot to write up.
i used these items:
batman48195
I never get tired of driving it!
Installed my clutch pedal extension. The pedal feels like it should given the position of the seat. I'm 5' 11" for others considering the mod. Going to take her for a spin.
Brian
Finally put my QTP's back in since the header and h-pipe install. Tried separate the side pipe from the flex joint because Kook's h-pipe outlet eliminates the need for the stock spacer if you use restrictor plates and the QTP's don't fit right. I ended up taking the pipes to a muffler shop to seperate them, cut a 1/2" off, and now they are a perfect fit and I can adjust the sound again from wife mode to my mode.
Fomoco302
Life is short. Live well!
Washed and waxed, put some road film on the front, checked tires pressures and all fluids. Trunk loaded and ready to hit he road at 3am tomorrow headed to Amarillo to join the Pony Drive. Vegas or bust!!
Finally got around to installing the 13/14 GT500 axlebacks that i've had for a year. Car's got a deeper tone now, I like it. Although the open side pipes kind of overwhelm the mufflers.
I'm half way through a Cortex Watts link install. Instructions say not to run a gasket but Lube Locker gaskets are so easy to deal with so I'll see what happens. Probably won't go so far as reusing my last gasket though. Changing out the weeping axle seal and bearings while I'm in there. Gear oil stinks.
Also, I installed an Aeroforce Interceptor guage in a Roush vent pod earlier in the week. Nice and easy install.
Once the Watts link is in, the car gets some fresh oil and will be heading to Buttonwillow next weekend.
