TMSBOSS
It depends on how many parameters you want to monitor and whether you want them to be static or cyclic. You can set a single gauge to cyclic scan up to 8 parameters displaying 2 at a time. I have mine set to ECT (CHT) and IAT currently. I'm ordering an oil temp sensor to add with my FRPP oil cooler so will probably just monitor ECT (CHT) and oil temp. If you want to see A/F bank one and two, you might want another gauge, or if you're going to add a sender for oil pressure etc. I have mine mounted in the A/C vent pod to the left of the steering wheel so just one gauge for me. I don't like the obstruction from A pillar gauges or on top of the dash.
[/quote]
I would like to add oil pressure, water temp for sure. Oil temp maybe. I have not tracked the car, yet so we will see about other data, A/F etc.
I am also not to excited about mounting on the pillar. Unsure how easy it will be to read the gauge if mounted in the A\C vent. Did you find yourself "Looking" for the gauge or is in fairly obvious? I would hate to miss something. Did that once with a 68 BB vette when a oil pump driveshaft broke on a fresh rebuild. Nope, motor was not "Fresh" by the time I saw the issue. Another reason to go with the idiot lights.
There are many good posts/links for installing, some from you I believe. Some here some on TMS. Just need to decide about mount location and number of gauges.
Thanks
Trace
[/quote]
Thanks
Trace
