06mach1 said:Drove in the rain a few times, so I guess I better keep the wipers. I do carry a spray can of window cleaner in the trunk though just in case.
Excellent point. I have never used the washer although I did use the wipers once when it rained during my first track day. In fact I've never tested the washer so I don't even know if it works.2012YellowBoss said:After all what is the worst that can happen, need to make a gas station pit stop for two minutes to clean the windshield?
5 DOT 0 said:The Roush side splitters add 20 lbs. of downforce over 150 MPH.
Thank you potholes. No news on the FRPP springs and I don't expect any for maybe two more months.
I wouldn't go out and buy the CJ grill until we have further confirmation that it will work with a stock hood. The only one I know of installed on a Boss so far uses a 302S hood. See below. It clearly states that it will not work with a 2010 hood. Maybe the 2011+ hood has as slightly different design?
http://www.fordracingpartsdirect.com/2010_COBRA_JET_GRILLE_p/m-5767-cj10.htm
http://www.race-mart.com/Ford_Racing-FMS-M-5767-CJ10.html
..Do you have a picture & or part number for the Roush side splitters (all I could find was decals)?
Also, any idea how much weight the FRP hood saves?
- Has anyone done a front/rear pinned FRP hood (to eliminate the hood hinges which, at least on other cars, I've noticed to be quite heavy).
Last - does the Kooks change the tone or loudness of the exhaust?
...Anyone running 19x10 all around?
Thanks,
Lee.
PeteInCT said:ANyone have any experience witht the lower Steeda springs ?
It should be on the second shortest day of the year! However, we're in for some mid-40s and sunshine through next Monday 8)5 DOT 0 said:Is that an icicle hanging from the front of the hood?
cloud9 said:Next up, paint the black center. Then a couple coats of clear and it's done 8)
Uploaded with ImageShack.us
