- 279
- 2
I'm not sure if others have had the same experience but I noticed the following over the last two track sessions with a square setup:
18 mm rear sway and tires all the same pressure (35 hot) - Lots of rear play. The oversteer was improved but still significant.
Stock rear (24 mm I believe) and rears 2 to 3 less than the front - Rear much more stable. Oversteer more improved than the above.
I will try the 18 mm rear sway (or no rear) with stiffer springs, but tire pressure will be my goto parameter first.
