- 6,559
- 8,213
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
It’s about oil control. Keeping it in the pan, not whipped up in windage, getting beat up, heated and turned into foam. The horse power gain is a bonus. The main purpose is to keep oil pure fluid and in the pan so the pump can send 100% foam free oil to the bearings. as soon as you loose that pressure fed oil wedge between moving parts bearings start to fail and we all know what happens after that.I apologize for my ignorance up front but I'm not getting the concept.
I always thought that getting the oil off the crank would help reduce horsepower loss. But how does it help reduce the chance of a blown engine?
Can the amount of oil that would otherwise remain up in the crank exceed 8 fluid ounces? Even a pint? With a larger capacity & baffled oil pan, how does that make a difference?
